Seat ABS Control Unit Coding
Christian1973
Post23-06-2005, 19:25    Subject: Seat ABS Control Unit Coding Quote
Hello!
I drive a Seat Cordoba GT TDI, manufactured in 1999, model 6K, with 110 horsepower.
First, the code was read from the old ABS, with the following result:
03 - Brake electronics.
1J0907379 G
ABS 20 IE CAN 0001
Encoding: 0
Then the ABS unit was replaced. It accepts the "0", but the diagnostic tool no longer shows any errors, but the ABS and brake warning lights are now constantly flashing. As far as I understand from the forum, it should be a multi-digit code.
I hope someone can help me.
Thank you in advance.
Christian.
Here's the background: Suddenly, the ABS light would occasionally illuminate. For the past few weeks, it has been on constantly, and recently, the brake warning light has also been on continuously. And to make things even more interesting, the brake warning light is no longer illuminating at all when the ignition is turned on. However, after driving about 2 km, it starts illuminating constantly again. During the inspection at the workshop, the diagnostic device displayed the message "ABS control unit defective" (without a specific error code!), and further navigation within the brake electronics menu was not possible. After checking all other components such as sensors, connectors, fuses, etc., and confirming that they were in order, I purchased a used ABS unit.
Translated on 26-08-2026, 19:00.
Back to top Profile PM Email
Lois
Post17-07-2005, 23:29    Subject: Seat ABS Control Unit Coding Quote
I once had a similar problem with a Toledo. It must have been the same coding issue, otherwise I always got the error message 'Control unit not correctly coded.' I tried with different vehicles until it finally worked. Used cars should be treated with caution because many have short circuits caused by accidents.
It's best to connect the control unit before installation and check if it can be programmed.
Greetings...
Translated on 26-08-2026, 19:03.
No new posts Audi APS Coding: How To & Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Airbag-coding with VCDS **Introduction:** This document... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Geschwindigkeitsregelanlage nachrüsten Seat IBIZA / Polo Troubleshooting & Guides
No new posts AFS coding for Seat Altea On-Board Diagnostics (OBD)
No new posts Coding trailer hitch Seat Leon ST 5F, year of manufacture... On-Board Diagnostics (OBD)
No new posts Coding for ABS control unit On-Board Diagnostics (OBD)
No new posts ABS control unit coding - custom configuration? On-Board Diagnostics (OBD)
