10 Cent Tuning | Posts 16+
Go to page: Previous  1, 2
eike
Post13-10-2002, 15:03    Subject: Quote
Hi, tinkerers,
I am currently considering the following option:
Instead of a switch, I would use two optocouplers connected in parallel. I would connect the LEDs of the optocouplers in series. For control, I am thinking of using the signal from the charging pressure sensor. This should be decoupled and the diode current should be linearized.
Then the tuning should automatically activate starting with a boost pressure of approximately 0.5 bar.
'Dadurch hätte man den Vorteil, dass das Tuning im Leerlaufbetrieb und im Teilastbetrieb inaktiv ist und die Einspritzmenge (Dauer) erst erhöht wird, wenn man den Hahn öffnet und auch der Ladedruck vorhanden ist.' This would allow one to eliminate the suspicious, short-lived smoke that occurs when performing a 10ct tuning and suddenly giving gas in the partial load range.
Okay, here's the translation:
Mal eine andere Frage: hat jemand Erfahrungen damit, wie lang das Kabel sein darf, wenn man das Tuning im Innenraum installieren will?
Greetings
Eike
Gremlin
Post13-10-2002, 15:40    Subject: Quote
Okay, let's try a different question: Does anyone have experience with how long the cable can be if you want to install the tuning system inside the car?
I didn't know...I used a 2.5m (flat) telephone cable because I didn't have anything else. I just wrapped the excess around the switch lever. No negative effects...
See you, Gremlin
OlliP
Post14-10-2002, 12:36    Subject: Quote
@ULF
Another pair of diodes isn't working!!!
'The smoothest ride, and not just at idle speed'
I'll try testing with Z-diodes.
Bye
Olli
No new posts 10Cent Tuning Technical Articles
No new posts Tuning: Intake & Intercooler - Optimization Guide Technical Articles
No new posts Fuel injector replacement: Tuning without electronic modi... Technical Articles
No new posts 10 Cent Tuning: Is it the same as...? Diesel Engine Technology
No new posts Tuning Chip for VW T4 2.5L 75kW - 10 Cent Diesel Engine Technology
No new posts 10 Cent Tuning warum Pin 2 und 3 ?????? Diesel Engine Technology
No new posts Diodes 20 Cent Tuning Diesel Engine Technology
