Schneemann Blaumann
Joined: 08/09/2003 Posts: 78 Karma: +2 / -0 Location: Wissen
21-05-2005, 13:18 Subject: Gear Shift Problem: 5th Gear Not Engaging |
Hello everyone,
It's just heartbreaking. This morning, as I was cheerfully whistling while overtaking a van on my way to work, I realized that after fourth gear, there was no fifth gear.
I just took a look, even though I actually don't know much about transmissions and gearboxes...
Okay, so: When I push the lever on the gearbox down, I can easily select the first, second, and reverse gears. But when I pull it up, it gets stuck. It's as if there are only four gears available.
GKB should actually be CTN.
What are the chances, in your opinion, that I need a new transmission? Or could it be something simple and inexpensive, surprisingly?
I know that it's difficult to do this remotely. But if I take my car to our VAG dealership, even just saying "good morning" will cost me 5 euros. Gruß Schneemann
Golf Plus Highline Bj. 09/2010 CFHC. eFH, eSP, Climatronic, PDC, AHK, ABS, ESP, GRA, MFA, LMAA, FDH, BSE, Brenderup Kippi 200 und ne Traumfrau auf dem Beifahrersitz.
Translated on 02-09-2026, 21:06.
ObenbeiMutti Guest
25-05-2005, 17:09 Subject: Gear Shift Problem: 5th Gear Not Engaging |
Hello.
Mine probably had the same number (233333) at the same time!
'First of all, I have no idea either!'
After I was no longer able to shift some of the gears, I had a diagnostic test drive, and the diagnosis I received was: 'Synchronous rings are worn out,' 'It's not worth repairing, get a transmission from a junkyard, a 02A or similar.'
Anyway, that wasn't the problem I had. After the spring engine flush, it seemed like the mechanics were prone to seizing, presumably because all the oil had been flushed out.
Perhaps you could try applying some grease to the mechanism, or maybe something a bit thinner like gun oil, and see if that helps it work properly again.
Greetings.
Translated on 02-09-2026, 21:08.
Schneemann Blaumann
25-05-2005, 17:59 Subject: Gear Shift Problem: 5th Gear Not Engaging |
Thanks for the helpful tip. I actually cleaned the engine just recently to make sure the TÜV (technical inspection) wouldn't have any issues. I just tried using some spray lubricant, let it sit, and lo and behold, it's still a bit stiff, but IT'S BACK!
Thank you, and happy holidays to everyone. Gruß Schneemann
Translated on 02-09-2026, 21:09.
Friesen Ulf Guest
30-05-2005, 21:05 Subject: Gear Shift Problem: 5th Gear Not Engaging |
I've had similar experiences before. Whether it's engine cleaning or anything else, I prefer not to do it. It only seems to be worth it if you want to get rid of your car.
Translated on 02-09-2026, 21:10.
JanT3TDi Blaumann
Joined: 07/07/2005 Posts: 34 Karma: +2 / -2 Location: Lübeck
26-07-2005, 17:15 Subject: Gear Shift Problem: 5th Gear Not Engaging |
With buses, the "egg cup" (the connection between the transmission and the linkage) is often a weak point. Unfortunately, this part is made of aluminum and is therefore prone to wear and tear.
Jan. T3 Multivan mit 1Z aus '95er Passat + Chip, 3H Getriebe + langer 5ter Gang
