Engine Control Unit (ECU) Locked?
Fred K
Post25-07-2005, 14:02    Subject: Engine Control Unit (ECU) Locked? Quote
Even though this question has probably been asked a hundred times before;
I couldn't find an answer.
I wanted to postpone my service appointment.
'It's not working because I'm getting an error message.'
'After a failed attempt, the control unit is locked.'
and would like to have some code.
What did I do wrong?
What kind of code do I need?
Who can help?
Translated on 31-08-2026, 2:51.
Rudi
Post25-07-2005, 14:36    Subject: Engine Control Unit (ECU) Locked? Quote
Hello Fred,
Hopefully, it wasn't a customer's vehicle icon_lol.gif.
Please describe what you entered where and with what.
until this error message appeared, and what kind of vehicle it is.
deals with.
Rudi
Translated on 31-08-2026, 2:52.
Fred K
Post27-07-2005, 9:24    Subject: Engine Control Unit (ECU) Locked? Quote
I didn't enter anything.
I wanted to reset the service interval display (oil change reminder).
'That's all.'
It's a 1999 Volkswagen Golf 4 TDI with 90 horsepower.
As software, I have a VAG COM 311.
Fred.
Translated on 31-08-2026, 2:53.
Post27-07-2005, 9:48    Subject: Engine Control Unit (ECU) Locked? Quote
Fred,
He wants to know HOW you intended to reset the service interval, i.e., which buttons you clicked on which control unit icon_rolleyes.gif.
Mati
Post27-07-2005, 9:49    Subject: Engine Control Unit (ECU) Locked? Quote
A more specific indication, such as an ICD code, would be helpful.
Take a look here:
[Edit Admin]
We don't need the link here.
It's all right there.
[/Edit Admin]
Greetings.
Mati.
Translated on 31-08-2026, 2:54.
Mati
Post27-07-2005, 10:52    Subject: Engine Control Unit (ECU) Locked? Quote
Okay, all clear, I feel purified icon_wink.gif.
Greetings.
Mati.
Translated on 31-08-2026, 2:55.
Fred K
Post27-07-2005, 13:15    Subject: Engine Control Unit (ECU) Locked? Quote
That's the thing, I haven't even pressed any buttons yet.
I wanted to add the word 'Diagnosis' to the map (I have to do this from memory).
describe (I'm currently in England) the 'unsecure' area.
As soon as I entered, I received a notification.
Translated on 31-08-2026, 2:56.
Post27-07-2005, 13:38    Subject: Engine Control Unit (ECU) Locked? Quote
Fred K wrote:
That's the thing, I haven't even pressed any buttons yet or anything.
I wanted to add the word "Diagnosis" to the map (I have to do this from memory).
describe (I'm currently in England) the "unsecure" area.
entered, and immediately the message appeared.
Fred K
Post27-07-2005, 15:50    Subject: Engine Control Unit (ECU) Locked? Quote
Hello Rainer,
I'll take some snapshots tomorrow when I'm back in Germany.
It's difficult to explain this from a distance.
VG,
Fred.
Translated on 31-08-2026, 2:57.
Fred K
Post07-08-2005, 10:10    Subject: VAG COM 311: The Question Answered Quote
Okay, so I tried it again, and VAG-COM is asking the following question:
VAG COM Login:
Most control units only allow a single login attempt. If an incorrect...
(and so on)
Then, a login code or a 7-digit PIN/secret number must be entered.
Where can I get the login code?
or PIN/secret code?
Thank you for the response. I can't find anything about it in the online VAG-COM manual.
VG,
Fred.
Translated on 31-08-2026, 2:58.
Post07-08-2005, 10:27    Subject: Engine Control Unit (ECU) Locked? Quote
Something about what you're saying is really confusing.
So, we still don't know why the engine control unit or instrument cluster is locked.
Now you want to log in, but you don't know which number to enter.
How are we supposed to know the number if you don't tell us what you want to do?
Hopefully, you made all the changes to the instrument cluster, right?
Are you trying to use a different engine control unit (ECU) in a vehicle?
Translated on 31-08-2026, 3:00.
Fred K
Post07-08-2005, 11:22    Subject: Engine Control Unit (ECU) Locked? Quote
why confusing?
Okay, here's what I'm doing now (maybe this is wrong too):
1.) Press Select.
2.) Press 01 for engine electronics.
3.) Press 11 to log in.
And then, the login procedure described previously follows.
What's confusing about this? Or is this the wrong way to approach the service interval display?
to postpone?
Translated on 31-08-2026, 3:01.
Rudi
Post07-08-2005, 12:02    Subject: Engine Control Unit (ECU) Locked? Quote
'Above, you wrote something about 'resetting the service interval'...'
What do you want in the engine control unit? It doesn't remember that!
Rudi
Translated on 31-08-2026, 3:02.
Post07-08-2005, 12:39    Subject: Engine Control Unit (ECU) Locked? Quote
Okay, I'm ready. Please provide the German text you want me to translate.
goettmann
Post07-08-2005, 14:22    Subject: Engine Control Unit (ECU) Locked? Quote
Or is this the wrong way to handle the service interval indicator?
to be put aside?
Yes
Please read the instructions that have already been posted to you twice.
Does it mention anything about the engine control unit?
No!
It clearly states 'AI - 017' there.
Those who can read have a clear advantage!
Translated on 31-08-2026, 3:03.
No new posts Software updates for Engine Control Unit, Assessment and ... General Tips
No new posts Engine Control Unit Errors: 2.5L V6 TDI (No Delete) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Engine control unit locked? On-Board Diagnostics (OBD)
No new posts Engine control unit locked, Golf 2 TDI AFN On-Board Diagnostics (OBD)
No new posts Engine Control Unit Locked: Troubleshooting Guide Diesel Engine Technology
No new posts Motor-SG locked On-Board Diagnostics (OBD)
