Major Issue: Troubleshooting Guide:-)
DeathAngel69
Post20-10-2002, 18:29    Subject: Major Issue: Troubleshooting Guide:-) Quote
Hello everyone. I'm still having a problem:
I recently got a 1992 Passat with a 90 horsepower TDI engine. After a long period of modifications and some writing, it's been running almost perfectly for several weeks now.
But one problem remains:
I'm experiencing a loud rumbling noise when starting quickly and accelerating in low gears.
Hypothesis: I suspect that instead of a TDI transmission, there's a different one installed.
IS: AYM transmission with a ratio of 71/18 = 3.94.
SHOULD: CHU, CTN, or CYP with a ratio of 60/19 = 3.15.
Could it be that the engine is vibrating so strongly because of...?
Could it be that the right (longer) driveshaft is rubbing against the motor mount? There are definitely signs of wear. I'm just not sure if this is caused by the rubbing or if the suspension is bottoming out.
Can the driveshaft move so far (e.g., due to a faulty differential) that it comes into contact with the engine mount under heavy load?
Thank you very much for your help/solution icon_smile.gif.
Translated on 02-08-2026, 21:11.
Jan6K
Avatar-Jan6K
Post21-10-2002, 8:45    Subject: Major Issue: Troubleshooting Guide:-) Quote
"Hi,"
"We really need to figure out which engine your gearbox originally came with, because the gearboxes from gasoline engines are too short, meaning you wouldn't enjoy driving on the highway with it (not to mention the fuel consumption), and they certainly aren't designed for the high torque of a TDI engine, so eventually it will break."
I think the overload might manifest as vibrations.
January.
1Z5 CFHF / AHB H4D
Translated on 02-08-2026, 21:13.
DeathAngel69
Post21-10-2002, 11:27    Subject: Best German Coffee: Buy Online & Enjoy! Quote
After calling the friendly person, he told me that the AYM transmission (like the one I have now) is from a 1991 Passat 1.9L with 64 horsepower.
I know it's too short, but I don't have any other time right now.
Trying really hard to get one.
Consumption is around 6-7 liters depending on the gas foot icon_smile.gif.
Maximum speed approximately 180 [units] at maximum RPM.
Does that help?
Translated on 02-08-2026, 21:14.
Post21-10-2002, 12:18    Subject: Response: [Your Question/Topic] Quote
DeathAngel69 wrote:
After a call to the friendly person, he told me that the AYM transmission (like the one I now have) is from a 1991 Passat 1.9L with 64 horsepower.
Maximum speed approximately 180 (units unspecified) at maximum RPM.
Does that help?
... yeah, kind of...
The gearbox is significantly shorter than the original, which means the torque acting on your engine and gearbox assembly is considerably higher. It's possible that the standard motor mounts may not be able to prevent the motor from tilting too far.
Translated on 02-08-2026, 21:16.
No new posts Problem with electricity. Auxiliary heater (G6 GTD) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ARL Turbo Issues: Troubleshooting & Solutions Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Automatic Transmission Problems: Audi A4 01N AFN General Tips
No new posts Fixed Issue, New Problem Arises Diesel Engine Technology
No new posts WFS Issues: Troubleshooting and Solutions On-Board Diagnostics (OBD)
No new posts Graphics Card Issues: Troubleshooting Guide Transmission, Chassis, Body & Interior
No new posts DPF Problem: 2.0 TDI BPW A4 Diesel Engine Technology
