Powerbox Setup: How to Configure Your Powerbox
freaky
Post09-09-2005, 18:27    Subject: Powerbox Setup: How to Configure Your Powerbox Quote
Hello, I have a power box, and I think it might be set too high. Anyway, I always get an error when I have it connected, and the motor goes into emergency mode.
I opened the box and found a small screw inside.
How far do I need to turn it, and for how long?
It's a Golf 3 with a 1Z engine.
Translated on 02-09-2026, 7:32.
Post09-09-2005, 19:07    Subject: Powerbox Setup: How to Configure Your Device Quote
freaky wrote:
hello, I have a power box, and I think it's set too high. How far do I need to turn it, and for how long?
Given the extremely precise description of the box here, my suggestion is:
Try turning it a quarter to a full turn to the right or left icon_twisted.gif.
Translated on 02-09-2026, 7:33.
freaky
Post09-09-2005, 19:13    Subject: Powerbox Setup: How to Configure Your Powerbox Quote
Sure, what should I write? I was there when it was bought. *g*
Okay, so it says 'ASA tuning box' on it, so it's not a branded product.
Okay, then I'll try that, or maybe I'll come up with another idea now.
Translated on 02-09-2026, 7:34.
Post09-09-2005, 19:19    Subject: Powerbox Setup: How to Configure Your Powerbox Quote
freaky wrote:
maybe another idea
Turn the knob in both directions all the way, and note the number of rotations in each direction. (Note: Potentiometers with a spindle may not have hard stops, but instead will continue turning and make a very faint clicking sound once per rotation.)
Then, you adjust the knob to the middle position between the two extremes, and during the test drive, you'll at least get a preliminary comparison.
freaky
Post09-09-2005, 20:18    Subject: Powerbox Setup: How to Configure Your Powerbox Quote
Okay, so I turned left, and the light comes on. When I turn right, the engine almost stalls, and the light is also on. So, if I turn left, the light comes on, but I don't hear any clicking.
It's a tuning kit from Autotechnik Saretz.
Translated on 02-09-2026, 7:35.
Post09-09-2005, 20:41    Subject: Powerbox Setup: How to Configure Your Powerbox Quote
freaky wrote:
It is a tuning kit from Autotechnik Saretz.
I once looked at the website. The picture of the box doesn't actually look like the worstthing ever.
Therefore, I suspect that the device turns on immediately or prematurely (instead of waiting for the RWG check), which could cause a malfunction -> either get it repaired or discard it.
Translated on 02-09-2026, 7:36.
gagag
Karma: +0 / -3   Thank you, like it!
Post11-09-2005, 11:09    Subject: Hire Employees: Find & Recruit Top Talent Quote
Here's how it works with a diagnostic device:
Open the engine control unit with VAG-COM, and in measurement channel 7 or 8, you will see the fuel temperature. Turn the screw to the left or right until the temperature reaches its maximum value (approximately 125°C). If you go further, you will see an "ERROR" message. (Clear the error memory). At 110°C, everything is optimized for me, and I don't get any error messages even in the summer. Best regards, gagag.
Translated on 02-09-2026, 7:37.
Post11-09-2005, 11:28    Subject: Hiring: Find Top Talent Now! Quote
Open the engine control unit with VAG-COM, and in the measuring block, channel 7 or 8 will display the fuel temperature. Turn the screw to the left or right until the temperature reaches the maximum value (approximately 125°C).
You are apparently describing the adjustment of a PD temperature fake box.
freaky, but it has a VP-TDI icon_exclaim.gif.
Translated on 02-09-2026, 7:39.
freaky
Post11-09-2005, 11:36    Subject: Powerbox Setup: How to Configure Your Powerbox Quote
I contacted the company, and the guy said I should try turning it two notches to the right, which I'm going to do now. Let's see; at least there are no more errors in the memory*g*.
No new posts Tuning comparison: Chip vs. Powerbox Technical Articles
No new posts Adjusting timing and PD element for common rail diesel en... Troubleshooting & Guides
No new posts PSI Powerbox: Powerful Performance Booster Diesel Engine Technology
No new posts Software optimization with Powerbox? Diesel Engine Technology
This topic is locked, you cannot edit or reply. Chiptuning: Increase Car Power & Performance Diesel Engine Technology
No new posts Powerbox Skoda Octavia - Performance Chip On-Board Diagnostics (OBD)
