Knee Pain Relief: The K/L Scale Explained
christians
Post22-10-2002, 19:57    Subject: Knee Pain Relief: The K/L Scale Explained Quote
I'm still unable to get the diagnostic connector 2.0 working.
Before I start troubleshooting and potentially damage something, I'd like to know what the typical voltage levels are for the K and L lines.
For my Audi 100 with an AAT engine, these are 12V (K) and 7V (L).
The short-circuit currents are 1 mA (K) or 0.1 (?) mA on the line-to-line measurement – the resolution of the multimeter isn't quite sufficient for that.
Best regards, Christian.
Translated on 26-07-2026, 4:30.
Post22-10-2002, 20:25    Subject: Windows XP Issues: Common Problems & Fixes Quote
Hi.
The 2.0 version also gave me a lot of trouble, mainly due to problematic values for parameters R 8 through R 11.
Okay, replace all of them with 1kΩ resistors, and possibly also increase the value of resistor R6 to something larger.
My adapter works stably with a 3.3 kΩ resistor for R6; the specified 2.2 kΩ resistor caused intermittent problems while the engine was running.
By the way, the adapter section on Rainer's website has been updated again icon_redface.gif.
The K-Line signal typically has a high level of around 10 volts or higher, and I don't know the low level. According to the definition (standard), values above approximately 7.5 volts should be recognized as high, and values below approximately 4.5 volts should be recognized as low.
I'm not sure about the L-Line; it seems my car only has a remnant of an L-cable.
Translated on 26-07-2026, 4:32.
christians
Post22-10-2002, 20:31    Subject: Knee Pain Relief: The K/L Scale Explained Quote
Thank you.
I'll give that a try.
Christian.
Translated on 26-07-2026, 4:33.
No new posts Function of the L-line? Diesel Engine Technology
No new posts 2. K-line at the connector On-Board Diagnostics (OBD)
No new posts Connecting the second one. K-Line On-Board Diagnostics (OBD)
No new posts VAGCOM: Troubleshooting Dual K-Line Issues Diesel Engine Technology
