Tensioner Bearing Bowls for 1Z, AHU, AFN, ALE
Post11-10-2005, 8:10    Subject: Tensioner Bearing Bowls for 1Z, AHU, AFN, ALE Quote
Does anyone know if the bearing shells of the idler pulley for the serpentine belt are available separately? I believe they are Teflon bushings that are pressed in.
I mean the folded part with the notch.
http://www.luxus-wg.de/~martin/auto_bilder/Spannrolle/DSC01152.JPG
Translated on 20-09-2026, 14:01.
Georg-TDI
Post11-10-2005, 8:30    Subject: Tensioner Bearing Bowls for 1Z, AHU, AFN, ALE Quote
While I can't give you a direct answer, according to what 'Freundlicher' said, these storage containers should also be available individually.
'In the past, I frequently had issues with the worn-out tensioner in the ribbed belt drive of the alternator. A friendly mechanic offered to replace the belt, pulley, pulley arm, bearing housings, and the tensioner for just under 300 euros. His words were: '...everything needs to be replaced, otherwise you'll be back here in a month because the next part will suffer consequential damage!'
Either it was a typical Volkswagen fairytale, or those bearing shells are actually available individually.
Does the file contain any information about that?
Georg.
Translated on 20-09-2026, 14:04.
Jockel
Karma: +15 / -1   Thank you, like it!
Post11-10-2005, 9:35    Subject: Tensioner Bearing Bowls for 1Z, AHU, AFN, ALE Quote
Enjoy your meal!
028 903 312
That could be it.
Hi, Jockel.
"Neu": Bora Variant, ASV
Translated on 20-09-2026, 14:06.
Back to top Profile PM Email
Post11-10-2005, 20:31    Subject: Tensioner Bearing Bowls for 1Z, AHU, AFN, ALE Quote
028 903 312 is a protective cap for the tensioning roller!
That's something completely different.
Translated on 20-09-2026, 14:07.
Jockel
Post12-10-2005, 14:16    Subject: Tensioner Bearing Bowls for 1Z, AHU, AFN, ALE Quote
dieselmartin wrote:
028 903 312 is a protective cap on the tensioner roller!
that is something completely different
Wow!
Okay, I'll search again to see where I got that number from...
Hi, Jockel.
Translated on 20-09-2026, 14:08.
