BlauBaer Guest
05-11-2005, 19:58 Subject: STG Golf III AFN: No Boost Sensor Connection? |
hello,
Does anyone know if there was a version of the engine control unit (ECU) that didn't have a connection for the boost pressure sensor?
I found one on e***, but the seller doesn't have the connector for my specific control unit. I can't imagine how it's supposed to work otherwise.
The engine control unit (ECU) is supposed to be from a Volkswagen Golf III AFN with the part number 028 906 021 GH or JG. Based on its appearance, it's an MSA15 (it looks exactly like mine).
I'm asking because I want to buy a new one. I already have one with the number 028 906 021 DF, and it's for a VW. A GH or JG would also fit, but it's strange if they don't have a connector.
best regards, BB
Translated on 10-10-2026, 3:08.
05-11-2005, 21:46 Subject: STG Golf III AFN: No Boost Sensor Connection? |
My information on this is:
Some AFNs (Air Flow Nozzles) have a pressure sensor in the intake manifold.
However, these are devices from the Passat 3B. Transparency, Teamwork
Translated on 10-10-2026, 3:09.
Profile PM Garage |
08-11-2005, 12:10 Subject: STG Golf III AFN: No Boost Sensor? |
BlauBaer wrote: | | STG soll aus einem Golf III AFN sein mit der nummer 028 906 021 GH od. JG. |
In the G3, I had the 021GH, definitely with a hose nipple. Gruß Ulf
Translated on 10-10-2026, 3:10.
Profile PM Garage |
Rudi Guest
08-11-2005, 12:32 Subject: STG Golf III AFN: No Boost Sensor Connection? |
G3 TDI engines (AHU, AFN and all newer 1Z models) use an MSA15.5 control unit with a 68-pin connector.
integrated charge pressure sensor and integrated altitude sensor.
Part number format: 028 906 021 xx.
Later (e.g., in the A3), there was the MSA15.7 with a split connector and without a boost pressure sensor.
(as Martin already mentioned).
Part number format: 038 906 018 xx.
Rudi
Translated on 10-10-2026, 3:11.
BlauBaer Guest
08-11-2005, 18:47 Subject: STG Golf III AFN: No Boost Sensor Connection? |
I'm just going to post the link so you can see for yourselves what I'm talking about.
If this is prohibited, I would like to apologize in advance and request that an administrator delete the link.
best regards
http://cgi.ebay.de/Motorsteuergeraet-Steuergeraet-VW-TDI-110-Golf-III-3-AFN_W0QQitemZ4587187851QQcategoryZ61544QQrdZ1QQcmdZViewItem
Translated on 10-10-2026, 3:12.
Rudi Guest
08-11-2005, 20:29 Subject: STG Golf III AFN: No Boost Sensor Connection? |
The picture seems quite clear...
The handwritten numbers would also belong to a Golf 3 AFN.
But - even with the latest G3 models (Variant and Cabrio - year '99), the G71 was...
integrated into the control unit; so it should have that connection!
The only MSA15.5 drives I know of that don't have this connector are those from the SDIs (e.g., 021FJ).
Whatever is being offered in the auction, I would stay away from it.
The price isn't exactly a bargain either.
Rudi
Translated on 10-10-2026, 3:13.
Julian Guest
08-11-2005, 20:42 Subject: STG Golf III AFN: No Boost Sensor Connection? |
Translating... |
[Translating...]Test  |
Rudi Guest
08-11-2005, 20:45 Subject: STG Golf III AFN: No Boost Sensor Connection? |
Hello Julian
Translated on 10-10-2026, 3:14.
Thomas Profi-Schrauber
Joined: 04/17/2002 Posts: 329 Karma: +2 / -0 Location: Darmstadt
10-11-2005, 13:33 Subject: STG Golf III AFN: No Boost Sensor Connection? |
Quote: | | The only MSA15.5 drives that I know of without this connector come from the SDIs (e.g., 021FJ). |
I would have said the same thing. AFN engine control units are simply more expensive than those from Sauger.
Greetings,
Thomas. -----------------------------------------------------
Audi S2 ADU Bj. 1993
Audi A3 TDI ASZ Bj. 2001
Translated on 10-10-2026, 3:15.
