Delta Radio: Questions and Answers
Jan03
2010 Volkswagen Polo
Post30-10-2005, 12:54    Subject: Delta Radio: Questions and Answers Quote
Hi.
Why do the Delta/Delta 6 devices have two antenna inputs? Can they simply be connected together?
"Furthermore, it seems there are two different versions, Delta and Delta 6. How can you tell the difference between the two types?"
As far as I know, only the Delta 6 can play self-burned CDs, right?
Jan.
Translated on 20-10-2026, 18:15.
Post30-10-2005, 15:09    Subject: Delta Radio: Questions and Answers Quote
Well, here's a guess: two tuners!
Tip: Check out the technical specifications on the VW website!
Translated on 20-10-2026, 18:16.
Jan03
Post31-10-2005, 19:51    Subject: Delta Radio: Questions and Answers Quote
Jep, ist mir klar dass das Delta zwei Tuner hat, doch das haben andere Radios auch und trotzdem nur einen Antenneneingang. Zwei Antenneingänge machen wohl nur Sinn, wenn man auch zwei Antennen hat. Die habe ich bei einem Golf aber noch nie gesehen. That's the question.
Technical specifications for the Delta 6 are easily found at VW, but not for the Delta. As far as I know, the only difference is the software version (the Delta has more DSP modes, and the Delta 6 can play CDs that have been burned). Surely, there must be a way to identify the difference through the part number, but how? And are there any other differences?
/Jan
Post31-10-2005, 21:20    Subject: Delta Radio: Questions and Answers Quote
Both players definitely play CD-Rs. However, my first Delta had trouble with CD-RWs, while the Delta 6 plays them without any problems.
According to my information, the Delta 6 has improved drive hardware. The Delta stopped playing CDs without errors altogether after about a year icon_sad.gif.
Translated on 20-10-2026, 18:17.
H.L.
Post17-11-2005, 22:47    Subject: Delta Radio: Questions and Answers Quote
Hello!
A radio with multiple inputs is a diversity receiver. It uses two antennas, such as a front and rear windshield antenna, and two tuners that select the better signal from each. The antennas should not be placed directly next to each other, otherwise the effect will not be as strong.
Some radios have multiple tuners but only one antenna input. In this case, the second tuner constantly scans the alternative frequencies of the selected station and selects the one with the best signal quality.
Christian.
Caddy CFHC TDI 2.0, Golf I GX, frĂźher mal Golf Variant TDI ALH, Passat 35i Kat-Diesel, Polo 86c, Passat Typ32CK 1,5 D
Translated on 20-10-2026, 18:18.
No new posts Golf 5 Radio Volume Problem - Repair Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A2 Radio: Won't Turn On After Parking? (8Z0) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A3 Radio Problem: Fix for 8L Models Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A few questions (I'm a diesel newbie) Questions about que... Diesel Engine Technology
No new posts Gas dynamics: How to calculate the pressure distribution ... Gasoline Engine Technology
No new posts LMM & Boost Gauge: Common Questions Answered Diesel Engine Technology
No new posts Radio dead On-Board Diagnostics (OBD)
