Passat TDI Flywheel: AFN Engine, 1998 Model.
KimR
Post24-11-2005, 22:39    Subject: Passat TDI Flywheel: AFN Engine, 1998 Model. Quote
Hello!
Does anyone here know if a flywheel from a PDI engine, for example, with 115 HP or 130 HP, will fit in my car?
Vehicle data:
Passat 3B TDI Variant, manufactured in 1998.
MKB AFN engine with 5-speed manual transmission.
Front-wheel drive.
According to my information, the diameter of PDI products is 240mm, whereas mine is 220mm.
'Will a larger 240mm fan fit on my kW? And is there enough space for the ZMS (presumably referring to a clutch or flywheel) inside the transmission housing?'
'Of course, I can reassemble a ZMS series. However, I would really prefer a stronger one that can handle more torque.'
Translated on 28-09-2026, 6:27.
Post26-11-2005, 8:44    Subject: Passat TDI Flywheel: Replacement & Repair (98) Quote
KimR wrote:
... Of course, I can reassemble a series of ZMS.
But I would really prefer a stronger one that can handle more torque. http://webcat.zf-trading.com/
} -> When searching, check the box next to the manufacturer "SRE". This will also display the reinforced clutches from Sachs.
Translated on 28-09-2026, 6:29.
No new posts Install Parking Heater in VW Passat 3BG Troubleshooting & Guides
This topic is locked, you cannot edit or reply. Passat 3BG 2005 Door Opening Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat MKB AVB: Fuel Leak Diagnosis & Repair Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Rear-wheel drive VW Passat, manufactured in 1998 Diesel Engine Technology
No new posts Oil Leak: A4 B5 2.5 TDI (1998) - Fix It! Diesel Engine Technology
This topic is locked, you cannot edit or reply. A6 TDI ESP Fault: 2.5L, 110kW, 1998 Diesel Engine Technology
No new posts Ford Galaxy 1998: Specs, Review & Price Diesel Engine Technology
