hotel-lima
06-12-2005, 21:44 Subject: Audi S8: Torque Issue? Check ECU Data Now! |
I used VAG-COM to read the measurement blocks from the engine and transmission control units of my Audi S8 (4.2L V8, 360 hp) to determine the maximum torque. For the engine control unit, I looked at blocks 120/122, and for the transmission control unit (5-speed Tiptronic), I examined measurement block 009. However, instead of the expected 430 Nm, I'm only reaching a maximum of 308 Nm. I've done several test drives (full-throttle acceleration, highway driving with multiple rapid accelerations), but 308 Nm is the highest torque I've ever measured. There are no error codes stored in the error memory.
I don't feel like the car is running poorly, but with a gradual loss of power, you might not notice it as easily.
The main reason I wanted to determine the torque was due to a transmission issue. Earlier this year, I had a transmission failure. The workshop said that the transmission failed because the engine control unit was sending incorrect, too-low torque values. In reality, the torque values were always higher, which caused the transmission to wear out very quickly. Apparently, this is a known problem with Audi vehicles and can only be detected through dyno tests, not by reading the error memory. The engine control unit was replaced along with the transmission.
I'm now wondering the following:
- Is it reporting a low torque again? That would explain why I don't feel like the car is running poorly. Also, it would put a lot of stress on the transmission again.
- Are the values actually correct, and is the car truly not delivering its full power? If so, the question is what's going on and why there's no error code in the memory. I need to measure this again with a higher sampling rate, but during a sprint from 0 to 100 km/h, based on the speed readings and timestamps when logging the measurement groups, I saw that it takes about 7.8 seconds to reach 100 km/h. Normally, the sprint should be completed in just over 6 seconds. This might be an indication of a lack of power.
Can someone give me some hints or tips on what might be going on, or what things I should check to figure out what's wrong?
Thank you in advance.
hotel-lima
Translated on 01-09-2026, 7:16.
vagtuning Guest
06-12-2005, 22:07 Subject: Audi S8: Torque Issue? Check ECU Data Now! |
However, the incorrect temperature readings in your example were transmitted due to a coolant temperature sensor that was not functioning correctly. They should have been able to tell you that completely from the start.
Since that part doesn't cost a fortune, it might be worth considering replacing it.
Translated on 01-09-2026, 7:19.
hotel-lima
06-12-2005, 22:16 Subject: Audi S8: Torque Issue? Check ECU Data Now! |
"This should then be determinable with the help of the measurement groups, right? I saw in a description of the measurement groups from Ross-Tech that there are several measurement groups that provide various temperatures. Which one would be relevant here?"
hotel-lima
Translated on 01-09-2026, 7:20.
Joined: 04/12/2002 Posts: 18128 Karma: +803 / -0 Location: St.Gallen 2018 Volkswagen T6
07-12-2005, 0:10 Subject: Audi S8: Torque Issue? Check ECU Data Now! |
How about the coolant temperature reading in the engine control unit?
Translated on 01-09-2026, 7:21.
Profile PM WWW Garage |
hotel-lima
07-12-2005, 0:26 Subject: Audi S8: Torque Issue? Check ECU Data Now! |
I was a bit puzzled by the measurement groups 130-137, as it appears that temperatures are being measured at different points there.
hotel-lima
Cosi Blaumann
07-12-2005, 0:44 Subject: Audi S8: Torque Issue? Check ECU Data Now! |
Hello.
"It would be a good idea to check the mass airflow sensor (MAF). It's a known issue, even in the S8. I've experienced it several times. After checking it, the values were around 310 Nm, and the airflow was approximately 115 grams."
The statement from Audi about the torque  , I'm not quite sure about...
Best regards, Cosi.
Translated on 01-09-2026, 7:22.
hotel-lima
07-12-2005, 0:54 Subject: Audi S8: Torque Issue? Check ECU Data Now! |
It didn't make sense to me either. But what can a customer do without accurate information and insider knowledge?
That's also the reason why I'm looking into this now. I don't want to rely entirely on the diagnoses from the workshop...
I'll take a look at the LMM (mass airflow sensor) and the coolant temperature sensor tomorrow.
What are the specified values for the mass airflow rate (MAF) for the S8? My last information was a minimum of 280 g/s at 7000 RPM. Is that correct?
hotel-lima
Translated on 01-09-2026, 7:23.
Cosi Blaumann
07-12-2005, 1:02 Subject: Audi S8: Torque Issue? Check ECU Data Now! |
Hello.
I don't have the exact values memorized right now, but I think it's around 160g/s. I'll need to check on my computer tomorrow.
Coolant temperature can either be checked by measuring the resistance at a specific temperature, or by relying on the readings obtained using VCDS (VAG Com diagnostic software).
Regarding torque, it's just a calculated value and can be affected by various factors, such as injection time and load.
Do you perhaps have a chip inside?
Best regards, Cosi.
Translated on 01-09-2026, 7:25.
hotel-lima
07-12-2005, 7:09 Subject: Audi S8: Torque Issue? Check ECU Data Now! |
No, there's no chip installed. Everything is 100% in its original condition.
So, could it be that the displayed torque is lower than the actual torque being applied, and thus the transmission is being damaged as a result?
hotel-lima
Translated on 01-09-2026, 7:26.
hotel-lima
07-12-2005, 13:02 Subject: New Data: Latest Measurements & Results |
I just completed a test run. The coolant temperature sensor is providing valid readings, and I observed a temperature increase from approximately 50°C to 90°C.
I also logged the mass airflow sensor data once. The maximum value was 199.69 g/s at 6920 RPM and 100% load.
Code: |
Time U/min LMM g/s load% Ign. 0BTDC
31.79 680 7.94 3.1 0.0
32.09 680 7.56 3.1 0.0
32.39 680 7.64 3.1 2.3
32.69 760 11.89 5.1 22.5
33.00 920 19.08 7.8 21.0
33.30 1440 28.50 11.8 23.3
33.60 1760 50.31 27.8 23.3
33.91 2160 56.11 59.6 24.0
34.21 2600 78.97 100.0 22.5
34.51 3040 98.75 100.0 21.0
34.82 3560 115.11 100.0 21.8
35.12 4080 136.31 100.0 23.3
35.44 4640 143.78 100.0 27.0
35.78 5200 163.25 100.0 27.8
36.14 5760 168.94 100.0 29.3
36.51 6360 184.08 100.0 30.8
36.89 6840 192.64 100.0 21.8
37.27 6880 192.39 100.0 6.8
37.63 5800 169.72 100.0 3.8
37.97 5000 143.14 100.0 30.8
38.31 5240 159.83 100.0 30.0
38.65 5440 157.64 100.0 30.0
39.01 5680 166.61 100.0 30.0
39.37 5880 181.86 100.0 30.8
39.74 6080 178.86 100.0 30.8
40.11 6320 186.89 100.0 31.5
40.49 6520 189.19 100.0 31.5
40.87 6720 191.78 99.6 32.3
41.24 6840 189.19 100.0 21.0
41.62 6440 193.53 100.0 6.0
41.96 5160 153.53 100.0 6.0
42.30 5000 152.83 100.0 30.8
42.63 5040 154.94 100.0 30.0
42.97 5120 151.14 100.0 30.0
43.31 5160 146.50 100.0 30.0
43.65 5240 154.94 100.0 30.0
43.99 5320 155.22 100.0 30.0
44.34 5440 151.42 100.0 30.0
44.69 5480 162.81 100.0 30.0
45.04 5560 161.58 100.0 30.0
45.39 5640 172.89 100.0 30.0
45.75 5760 179.39 100.0 30.0
46.11 5840 173.97 100.0 30.8
46.47 5880 148.39 48.6 15.0
46.82 5840 42.47 12.9 19.5
Code: |
61.21 4680 169.61 42.4 27.8
61.53 4800 146.67 100.0 27.8
61.86 4880 144.83 100.0 29.3
62.20 4960 150.83 100.0 30.8
62.53 5080 151.61 100.0 30.0
62.87 5200 159.61 100.0 30.0
63.22 5320 157.39 100.0 30.0
63.56 5480 154.03 100.0 30.0
63.92 5600 167.72 100.0 30.0
64.27 5760 176.08 100.0 29.3
64.64 5880 172.11 100.0 30.8
65.00 6000 175.61 100.0 31.5
65.37 6160 176.39 100.0 31.5
65.75 6280 177.22 100.0 28.5
66.12 6440 181.31 100.0 28.5
66.50 6560 190.92 100.0 31.5
66.88 6680 194.42 100.0 32.3
67.25 6800 187.56 100.0 25.5
67.63 6920 199.69 100.0 20.3
68.01 6480 186.36 100.0 5.3
68.35 4960 144.31 100.0 8.3
68.68 4800 136.39 100.0 29.3
69.00 4800 136.33 53.3 13.5
69.32 4760 30.92 10.2 15.0
69.65 4720 15.69 6.3 23.3
69.97 4640 16.53 6.3 30.8
According to the information I have, the target values are between 280 and 300 g/s. Can anyone confirm this? If that's correct, then my mass airflow sensor (MAF) is apparently providing too low values. I would then check the MAF sensor and try to determine if the catalytic converters are functioning properly.
hotel-lima
Translated on 01-09-2026, 7:27.
