Chip Tuning 115 PS - Performance Upgrade
dieselschräubchen
Post04-05-2002, 16:01    Subject: Chip Tuning 115 PS - Performance Upgrade Quote
Hello!
I'd like to get a chip for my A4 115 hp (285 Nm). ******** is offering a good deal with an extra 80 Nm of power. I've used ******** chips before (90 hp) and have been satisfied with them so far. However, an extra 80 Nm seems quite significant; ******** doesn't usually offer such a large power increase for other TDIs. Does anyone have chipping experience with my model?
Diesel screws.
Translated on 06-10-2026, 8:16.
JET
Post04-05-2002, 17:57    Subject: Chip Tuning 115 PS - Performance Upgrade Quote
Hi, I'm using this engine in a Golf Variant and I have a chip from MTH. They are a software developer that sells tuning software to other tuners, such as B&B. They claim 145 hp and 350 Nm of torque. If you have a very good example, it might be slightly more. After the tuning, the engine is much more agile across the entire rev range. It has more power everywhere and reacts more sensitively to accelerator pedal commands. The engine's running culture has improved significantly; it now runs smoother, more refined, and quieter. The fuel consumption hasn't changed. Before the tuning, the speedometer showed 200 km/h, and after, with some effort, it reached 220 km/h. However, the A4 only has a 5-speed gearbox, so the top speed isn't quite as high. In the standard configuration, the A4's engine in 5th gear reaches 4200 rpm, while with the chip, it reaches 4400 rpm, which means 10 km/h more top speed. It reaches the new top speed faster than it used to reach the old one. However, all these figures refer only to the MTH software. More power and torque, however, are supposedly critical for the engine and could therefore reduce its durability. I hope I've been a little bit helpful.
Translated on 06-10-2026, 8:18.
No new posts Tuning comparison: Chip vs. Powerbox Technical Articles
No new posts AFN Chip: What it is and how it works On-Board Diagnostics (OBD)
No new posts AFN Timing Belt & Chip Replacement Diesel Engine Technology
No new posts TÜV and Chip: What You Need to Know Diesel Engine Technology
No new posts new chip Diesel Engine Technology
