OBD Tuning: How To & Guide
slizer
Post28-12-2005, 9:43    Subject: OBD Tuning: How To & Guide Quote
I've been reading a lot about OBD II tuning lately, and I'm thinking of trying it out on my Passat 1.9 TDI PD with 115 hp.
How should one proceed in this case?
What else do I need besides an ODB diagnostic interface and VAG-Com?
How exactly is it done?
What exactly is being changed in the control unit?
Does anyone know of a detailed guide on how to proceed?
Is there a how-to guide?
I am a computer scientist, so I can roughly imagine what is being done, but I don't know why and how, and especially where? icon_smile.gif
The best way to explain it is like with the bee and the flower icon_wink.gif, so that I can understand it too.
Thank you very much!
SlZ
Translated on 27-10-2026, 18:34.
Post28-12-2005, 10:31    Subject: OBD Tuning: How To & Guide Quote
Okay, I don't really want to complain, but please read this.
And then, consider asking for some background information on this forum, especially since it's your first post. Many things have already been explained. A basic understanding of how a motor works is generally expected. This also includes a general understanding of what a MSG (presumably a specific type of device) is capable of.
So, why don't you give it another try?
Translated on 27-10-2026, 18:36.
Post28-12-2005, 18:09    Subject: OBD Tuning: How To & Guide Quote
matthiasTDI96 wrote:
A basic understanding of how a motor works is generally expected. This also includes a very general understanding of what a MSG (presumably a specific type of device) is capable of doing.
Yep, and the second stage (chip tuning) is the source of income for an entire industry, and accordingly, they guard their secrets closely. As a result, specialized tools (hardware and software) for tuning are traded at very high prices.
See, for example, chiptuningforum.com.
Translated on 27-10-2026, 18:37.
Troubleshooter
Post02-01-2006, 18:25    Subject: OBD Tuning: How to Do It Right Quote
After your Passat has a quartz oscillator in the speedometer, if it can even be flashed at all (not all models with 115 hp can be flashed), it can only be done on a diagnostic machine.
Basically, it's quite simple: you just need to buy a flash booster or an ACR, a WinOLS version for editing the maps, and then you can get started.
Remove the ECU, connect it to a device, read the EEPROM, modify the maps (e.g., boost pressure, soot reduction, fuel injection quantity, injection duration, etc.), write the modified file back, and test drive.
Okay, let's be serious. Unfortunately/thankfully (it depends on your perspective), reprogramming an ECU is not as simple as flashing a USB stick. Also, there's no 'PS map' in the software that you can simply increase by 20% and be done. This requires experience, technical know-how, and some technical equipment.
'Best regards,'
Matthias.
Translated on 27-10-2026, 18:39.
fulda
Karma: +4 / -3   Thank you, like it!
Post04-01-2006, 11:35    Subject: OBD Tuning: How To & Guide Quote
The cost of such an acquisition would never be worthwhile if you only want to "tune" your own vehicle - moreover, a lot can go wrong in the process! I would rather go to a tuner you trust icon_neutral.gif.
Translated on 27-10-2026, 18:41.
Troubleshooter
Post04-01-2006, 11:53    Subject: OBD Tuning: How To & Guide Quote
The cost of such an acquisition never pays off if you only want to 'tune' your own vehicle - moreover, a lot can go wrong! I would rather go to a tuner you trust icon_neutral.gif.
Absolutely correct.
You wouldn't build a garage and set up a complete workshop just to change the oil in your own car icon_smile.gif.
@fulda
Where in Styria are you from?
Translated on 27-10-2026, 18:42.
fulda
Post04-01-2006, 12:13    Subject: OBD Tuning: How To & Guide Quote
@Troubleshooter
District of Radkersburg new_tomato.gif, but sometimes I drive past the Autokorbel-Center in Hartberg icon_wink.gif why?
PS: good comparison icon_twisted.gif
Translated on 27-10-2026, 18:43.
Troubleshooter
Post04-01-2006, 13:06    Subject: OBD Tuning: How To & Guide Quote
@Troubleshooter
Just so, it adds a bit more personality to the forum when we know a little bit about each other. icon_smile.gif
Translated on 27-10-2026, 18:44.
No new posts 10Cent Tuning Technical Articles
No new posts Tuning: Intake & Intercooler - Optimization Guide Technical Articles
No new posts Fuel injector replacement: Tuning without electronic modi... Technical Articles
No new posts Good tuning, bad tuning? Diesel Engine Technology
No new posts How to administer LLK (medication)? Diesel Engine Technology
No new posts Intermittent connection! But where? Diesel Engine Technology
This topic is locked, you cannot edit or reply. Swap-but how? Diesel Engine Technology
