Install Battery Siren VW G4 MJ 2001?
bafische
Karma: +22 / -0   Thank you, like it!
Post12-01-2006, 17:56    Subject: Install Battery Siren VW G4 MJ 2001? Quote
I have a G4 2001 with a Comfort Control Unit (CCU) with part number 1J0 959 799 AH, index 02K. Can I connect the original VW alarm siren (part number 1J0 951 605, with a 3-pin connector) to terminal T15/3 of the CCU, as well as to the power supply and ground? Is it possible to reprogram the CCU to the -UK- configuration?
Currently, the horn (2-pin connector) is connected to terminal T15/11 of the comfort module or to ground.
I tried searching, but I couldn't find a clear or relevant post.
Have you ever done something like that before? What's the difference between a battery-powered siren and a horn?
Thank you for your help.
"Luft und Menge müssen stimmen - der Rest ist Physik."
unumstössliches Gesetz in der Dieselmotorenentwicklung
Translated on 30-09-2026, 15:56.
No new posts Polo Combo Instrument Cluster, 10.99-09.2001 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Central Locking Failure: A6 Doku 4B (10/2001) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A6 4B from 9/2001, window opening sealing faulty Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Timing Belt Kit for PD AJM 2001 Diesel Engine Technology
No new posts Performance loss Golf TDI PD, Year 2001, 115 hp Diesel Engine Technology
This topic is locked, you cannot edit or reply. PDE Changes: Before and After 12/2001 Diesel Engine Technology
No new posts Audi A4 2.5 TDI Service: 2001 Model Help On-Board Diagnostics (OBD)
