"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Ein leichter Wind weht durch die Bäume, und die Blätter rascheln leise. Es ist ein wunderschöner Tag, um draußen zu sein."
Hello everyone,
My VW Golf is giving me trouble!!!
Yesterday evening, I drove about 50 km on the highway, quite quickly. Approximately halfway, the creature emitted a peculiar sound
The noise (audible) occurs in the low-pressure range starting at 0.9 bar. It's a moderately loud "air escaping" sound. My initial thought was somewhere in the low-pressure cooling system. But that's not the case. The boost pressure is fully present (as indicated on the boost gauge). My second thought was a crack in the exhaust or downpipe. However, I don't think that's it, because you should at least be able to hear a crack or small hole, even in the non-boosted range, and the boost pressure would increase, even if only slightly. When the hood is open, you can't hear anything because 1. the engine is loud, and 2. there's no load and therefore little boost pressure.
I thought, well, whatever, the boost pressure is there, who cares?
I got home without any problems.
This morning, I started the engine three times (-5 degrees Celsius, 100 miles on odometer), and it started normally after 2 seconds as usual. After driving less than 50 meters, the coolant warning light started flashing. Since I did the odometer conversion (and also replaced the head gasket), I haven't had to top up the coolant. My first thought was that maybe it's due to the cold, which is causing the low level. I went home and checked, and the expansion tank was empty.
I still had half a liter left, so I poured it in. About 5 kilometers later, the warning light came on again. I checked everything for leaks, but I couldn't find anything. I replaced the coolant reservoir cap, as it was faulty on the previous owner's car, and topped up the coolant.
Okay, here's the translation:
"I drove about 30 km on the highway, pushing it to the limit. I opened the cap, and then a lot of stuff came out (too much pressure?)."
When opening it slowly, nothing has ever leaked out before... So, I looked inside the top, and there's foam inside. I removed the foam with a cloth, closed the lid, drove a short distance, opened the lid again, and there's foam again.
What's going on now?
Is it related to air escaping from the turbocharger? Could there be a crack in the turbocharger, allowing the overpressure from the turbocharger to enter the turbocharger's coolant lines? That would explain the foaming! The pressure in the coolant hoses with a warm engine is normal.
Klar, normal tippt man auf Kopfdichtung, aber die hab ich vor 20Tkm gewechselt und wenn der Motor nicht heiß wird hält die ewig!!! Vorgänger bei 340Tkm verkauft mit 1. Kopfdichtung. Außerdem müsste dann das Kühlwasser am Ausgleichsbehälter nach Abgasen riechen. Tut es nicht. Wenn er das KW mitverbrennt, sollte er ja auch weiß rauchen?? EbenfalUnfortunately, nothing.
Guys, what do you think? Where should I start? What seems most reasonable?
Thank you for the tips.
Frank.
