GT1749VB: Oil Pressure Pipe for Turbocharger.
Post17-01-2006, 21:30    Subject: GT1749VB: Oil Pressure Pipe for Turbocharger. Quote
According to the documentation, the oil pipes from the filter to the turbocharger appear to be partially disassembled in some cases, depending on the specific engine code.
The ASZ engine has the following part numbers: 038 145 771 AA for the Leon, 771 N for the Octavia and Golf, 771 G for the Ibiza, and 771 R for the Polo and Sharan/Alhambra.
The ARL uses the 771 AA in the Leon and the 771 N in the Golf. The BPX also uses the 771 N.
The new 150 hp 1.9-liter engine in the Sharan/Alhambra, codenamed BTB, has the same part number (771 R) as the ASZ, but features a KKK turbocharger instead of the GT1749VB.
I'm now wondering if the GT1749VB turbocharger I want to install in my Polo also requires a different oil feed pipe (like the 771 N used in the ARL Golf), or if I can continue using the 771 R without the turbo suffering from oil starvation.
Does anyone here know anything about the different types of oil pipes?
Is the oil flow in the loader determined by the various pipes and their inner diameters?
It doesn't seem to be related to the different oil filter housings (Golf vs. Polo platform): For example, the Ibiza BPX has the "compact" filter unit of the Polo, but still uses the same oil pipe as the Golf with its larger filter unit...
Oh yes: the oil pump is the same for all of the engines mentioned.
Translated on 24-08-2026, 4:20.
Post18-01-2006, 17:24    Subject: GT1749VB: Oil Pressure Pipe for Turbocharger. Quote
Today, I had the opportunity to compare an ASZ engine with mine, using my own engine as a reference.
The oil line in the Gulf region (according to the documentation, it's the same as for the ARL) is painted and secured on the filter side with a hollow screw that passes through it.
My Polo has a union nut on the filter side, and the exposed pipe appears to be made of a stainless steel alloy.
The outer diameters are practically the same: approximately 8.2 mm for the Golf (including paint) and 8.1 mm for the Polo, which suggests that the inner diameters are also likely to be the same.
Could there still be a reason to install the oil line from the (ARL) Golf along with the ARL charger?
Translated on 24-08-2026, 4:23.
No new posts VTG Loader: Operating principle and settings Technical Articles
This topic is locked, you cannot edit or reply. AFN with GT1749VB turbocharger on Audi A4 B5 Diesel Engine Technology
No new posts KP39B to GT1749VB Turbocharger Swap: Results Diesel Engine Technology
No new posts ARL Turbo (GT1749VB) on AFN: Installation Tips Diesel Engine Technology
No new posts Urgent: Differences between GT1749VA and GT1749VB exhaust... Diesel Engine Technology
