Passenger Door Electric Failure: Common Causes & Fixes
duca
Post18-01-2006, 13:10    Subject: Passenger Door Electric Failure: Common Causes & Fixes Quote
Hello.
"In my Passat 1.9 TDI (manufactured in December 1998), the electrical system occasionally fails, meaning that features like the mirror controls, central locking, and window lifters stop working, except for the puddle light."
- Could the problem be with the control unit itself, or more likely with its wiring?
- Where is the control unit located?
Thank you very much for your help.
Translated on 02-08-2026, 19:50.
Post18-01-2006, 13:18    Subject: Passenger Door Electric Failure: Common Causes & Fixes Quote
First, check the connection between the car body and the door. There might be contact problems there, and if it only happens occasionally, the likelihood of a loose connection is quite high, especially since the door light turns on when the door is opened.
Translated on 02-08-2026, 19:51.
duca
Post18-01-2006, 15:09    Subject: Car Body Repair: Door Replacement & Services Quote
The contact between the door and the body is fine; it needs to connect to the control unit, but I'm not sure where that is located.
Translated on 02-08-2026, 19:52.
duca
dieselschrauber likes this.
Post19-01-2006, 21:56    Subject: Passenger Door Electric Failure: Common Causes & Fixes Quote
Thank you for your help; the cables in the door seal were broken. I soldered everything back together and insulated it, and now everything is working again! icon_lol.gif
Post20-01-2006, 8:45    Subject: Passenger Door Electric Failure: Common Causes & Fixes Quote
"You're welcome, as described, it's a typical issue with VW cars. It's a shame, really. Thanks for the feedback."
Translated on 02-08-2026, 19:53.
No new posts Audi A6 4B: Faulty TV Tuner - Repair Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J: GRA Failure When Turn Signal Is On Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A4 Documentary: Fuel Drop After Reserve (1999) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passenger Airbag: How to Reactivate It On-Board Diagnostics (OBD)
No new posts Hi-Li Door: Sporadic Communication Error 1000 On-Board Diagnostics (OBD)
No new posts Passat 3B Rear Door Won't Open? Transmission, Chassis, Body & Interior
No new posts Audi A4: Rear Left Door Won't Open? Transmission, Chassis, Body & Interior
