holzbein Blaumann
20-01-2006, 14:10 Subject: CAN Bus Transmission VAG 504.1 |
Enjoy your meal.
Bei dem VAG 504.1 ist mir aufgefallen, nachdem ich den Test unter Einstellungen durchgeführt habe, das dort unter anderem Stand `CAN-Übertragung nicht möglich`. Liegt das jetzt daran, das das mein Fzg das nicht unterstützt oder weil ich so einen Adapter von RS-232 auf USB benutze. SonI've lost everything.
And whenever I try to use the LED buttons, the program always crashes. I'm not even sure what those buttons are supposed to be used for.
Thank you very much.
Translated on 24-10-2026, 21:01.
Rudi Guest
20-01-2006, 14:17 Subject: CAN Bus Transmission VAG 504.1 |
Which diagnostic adapter are you using?
Rudi
Translated on 24-10-2026, 21:02.
holzbein Blaumann
20-01-2006, 16:56 Subject: CAN Bus Transmission VAG 504.1 |
Okay, so it's called P232C "HEX-COM+CAN".
Rudi Guest
20-01-2006, 17:09 Subject: CAN Bus Transmission VAG 504.1 |
Then your vehicle does not have a CAN-Bus  .
Rudi
20-01-2006, 17:41 Subject: CAN Bus Transmission VAG 504.1 |
The correct message text during the adapter test (assuming the P232C is mine) is: 'CAN: not ready'. Please, if you are going to quote messages, then please quote them correctly  .
It only indicates that there is no CAN bus connection at the diagnostic connector, nothing else.
Quote: | | And with the button LEDs, the program always crashes. | I'm not even sure what that button is needed for.
Very strange, I've never experienced a crash like that before. It works perfectly fine with the 512.0 version as well. Is the adapter directly connected to the COM port?
The button only makes the LEDs on the adapter blink, which indicates that at least the electrical connection of the cable to the PC is working.
Translated on 24-10-2026, 21:03.
Profile PM WWW Garage |
Ross-Tech-Support Profi-Schrauber
20-01-2006, 18:06 Subject: CAN Bus Transmission VAG 504.1 |
As mentioned previously, the status message does not directly indicate the status of the interface, but rather the status of the vehicle's diagnostic lines. As previously mentioned, if "CAN: Not ready" is displayed, it usually means that the vehicle does not support diagnostics via CAN, and this must be determined on a case-by-case basis, depending on the specific vehicle used for the test. If this error message appears on a vehicle that does support diagnostics via CAN, the respective manufacturer or dealer should be consulted.
The LED test was originally designed for "simple" hardware, but for current "intelligent" systems like HEX and KEY, it is actually outdated and may be removed in future versions.
@ holzbein
If you want a specific answer, you would also need to tell us which vehicle you tested on, or the operating system used, etc.
Translated on 24-10-2026, 21:05.
holzbein Blaumann
20-01-2006, 20:19 Subject: CAN Bus Transmission VAG 504.1 |
First of all, thank you very much for all the answers.
I apologize for the delay, but I didn't have that information readily available.
Okay, I have a Volkswagen Golf IV TDI with 74 kW, engine code AXR, manufactured in December 2001.
I thought the test was just an initial setup to check if all possible functions are available, and then the program would handle the rest individually. But you never stop learning.
Translated on 24-10-2026, 21:07.
20-01-2006, 20:39 Subject: CAN Bus Transmission VAG 504.1 |
holzbein wrote: | | So, I have a Golf IV TDI 74KW 1J with the engine code: AXR, manufactured in December 2001. |
Definitely no diagnosis via CAN, which means the message is correct.
holzbein wrote: | | I thought the test was initially just a basic setup to check if all possible functions are available, and then the program would handle the rest individually. |
Here's an excerpt from the RKS manual:
Quote: | The 'Test' button checks whether the adapter is connected.
Important: With the diagnostic adapters of the professional systems, the 'Test' button is used for...
at the same time, the licensing of VAG-COM must be checked and updated! Therefore, the button must...
must be activated to utilize the full range of features offered by VAG-COM.
can. |
Here's a more detailed way of putting it...
...during the test, it is generally checked which interface is connected, if any, and the hardware's serial number is read. If necessary, the software is activated to enable the full range of functions. Furthermore, the individual diagnostic lines are checked, and a status message is displayed at the end.
Translated on 24-10-2026, 21:09.
