Nozzle application designations
TT - Diesel
Post22-01-2006, 15:20    Subject: Nozzle application designations Quote
Hello everyone,
It seems I have some catching up to do regarding fuel injectors.
Here in the forum, people are constantly talking about 184s, 205s, and other nozzles.
I can certainly imagine that this refers to the diameters (0.184mm).
refers to the drilling operations involving the injection of fluids.
But could someone please translate all of this into the 'standard terminology' used by the manufacturers?
For example, a size 184 might be a DN0SD273 or a DSLA 150 P 357, or something like that?
Perhaps there is also a list specifying which engine, nozzles, and nozzle inserts are standardly installed. The injection pressure would also be helpful.
Thank you very much in advance for your efforts.
TT - Diesel.
No new posts Use of HVO in diesel engines Diesel Engine Technology
No new posts 4 nozzles with NHG instead of 3 standard nozzles Diesel Engine Technology
No new posts ALH Injectors: Compatibility with AFN Engines? Diesel Engine Technology
No new posts AHU with 0.205 nozzles Diesel Engine Technology
