"Isn't it true that the alternator must match the engine code? I have an AFN engine, which was also used in many other models. Different alternators were installed in those models. Actually, only the freewheel mechanism in my alternator is defective, and before I spend 90€ on a new one, I could buy a used one from E***. Or is the freewheel mechanism available somewhere cheaper?"
Before I would buy a cheap, unreliable clutch from 321, I would rather buy a new clutch pack, but everyone is free to do as they please.
By the way, you can find cheaper options for the "free-roaming" feature; just use the search function, and you'll find plenty of information.
Greetings,
dieter
T3 syncro 16 AFN
... or I can give you my "non-free-spool" reel, because I specifically upgraded it with a free-spool function and now I have the fixed-spool reel left over.
