PIN Compatible? Easy Replacement - Is it Possible?
leo_b
Avatar-leo_b
Post11-02-2006, 18:45    Subject: PIN Compatible? Easy Replacement - Is it Possible? Quote
hi,
I have a T4 with an 88 hp TDI engine (engine code: AJT), model year 2000.
Can I simply exchange the existing msg: 074 906 018 B with the one from acv: 074 906 018 C?
What should be considered?
Best regards, Leo.
p.s.: An LLK (low-loss coupling) from ACV is installed.
Translated on 28-10-2026, 6:26.
Rudi
Post11-02-2006, 19:45    Subject: PIN Compatible? Easy Replacement - Is it Possible? Quote
The immobilizer needs to be adjusted. The rest might work.
Rudi
Translated on 28-10-2026, 6:27.
No new posts Passat V157: How to Replace and Calibrate CBDC Module Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW Passat: ESP Light On - What to Do? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Caddy 9K9: Engine Stalling, Error Code 1268 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A3 TDI: Engine Stalling - Common Problem? On-Board Diagnostics (OBD)
No new posts TDI Engine Failure: Common Causes & Fixes Diesel Engine Technology
No new posts Golf V TDI 2.0 PD: Engine Stalling Issues On-Board Diagnostics (OBD)
No new posts Golf 3 TDI, 1994, keeps stalling Diesel Engine Technology
