PD Motor Performance: Maximize Your Output
Juergen
Post12-11-2002, 10:52    Subject: PD Motor Performance: Maximize Your Output Quote
Hi everyone!
After repeatedly reading about performance increases in PD engines reaching up to 185 horsepower, I decided to do some research on Bosch's website and came across something surprising:
Bosch specifies the maximum power output for the PD system (UIS-P1) used in passenger cars as 25 kW per cylinder.
According to the 'Adam Riese' rule of thumb, for an engine with 4 cylinders, that would be 100 kW, or 136 horsepower.
Therefore, there should be no PD engines with more than 136 horsepower.
Can someone explain this to me?
For those who would like to read more:
Bosch, Technical Training, Diesel Engine Management, Diesel Injection Systems, UIS/UPS, ISBN 3-934584-17-9.
Best regards, Jürgen.
Translated on 02-10-2026, 17:07.
Post12-11-2002, 13:19    Subject: PD Motor Performance: Maximize Your Output Quote
These figures are only approximate. Technological progress doesn't stop here either.
I've also read figures of 30, even 35, kilowatts per cylinder.
Translated on 02-10-2026, 17:09.
chrigu
Post13-11-2002, 23:19    Subject: PD Motor Performance: Maximize Your Output Quote
Hello, fellow diesel enthusiasts.
I checked the Bosch documents you mentioned.
The injection volume is specified as 60 mm³ per stroke.
That would be at 2000 revolutions per minute and a specific consumption rate.
from 200 g/kWh (density 0.83 g/cm³) for just a...
Torque of 285 Nm is sufficient icon_question.gif icon_question.gif icon_question.gif.
best regards, chrigu
Translated on 02-10-2026, 17:10.
Stefan
Post14-11-2002, 8:14    Subject: PD Motor Performance: Maximize Your Output Quote
That's correct. The 25 kW per cylinder is a specification based on a defined amount of fuel and piston stroke. However, this value of 25 kW refers to the distributor injection system, not the pump/nozzle system.
Chip tuners increase the maximum fuel injection volume/piston stroke, which allows for more power. However, this is limited by the fuel injectors. Since the injection pressure cannot be increased, the injection duration must be extended. However, you cannot inject fuel for an unlimited amount of time. Eventually, the time window for complete combustion of the fuel mass is no longer sufficient, and the limit of power increase is reached. To achieve more power, you would need larger injectors or a modification of the fuel injection pump (e.g., a 11mm pump plunger).
Translated on 02-10-2026, 17:11.
Post14-11-2002, 16:53    Subject: PD Motor Performance: Maximize Your Output Quote
Hi.
if there isn't a calculation error in there icon_question.gif icon_question.gif.
The 81 kW TDI injects a maximum of approximately 40 mg/stroke and, with this, achieves from the factory a nominal torque of 235 Nm.
Therefore, 60 mg should be sufficient for approximately 50% more torque, which would be somewhere around 350 Nm.
Translated on 02-10-2026, 17:13.
Gremlin
Post14-11-2002, 18:15    Subject: PD Motor Performance: Maximize Your Output Quote
I also have that little book as a PDF.
Take a look inside the cover.
bei mir steht da '1. 'Issue 1999'.
Since I got this directly from the intranet, I assume it's the latest version icon_wink.gif.
btw: what I mean is that there are definitely newer pump elements available now. The 25kW per cylinder is just a guideline.
CU Gremlin.
Translated on 02-10-2026, 17:15.
chrigu
Post14-11-2002, 18:24    Subject: PD Motor Performance: Maximize Your Output Quote
Hello.
The maximum injection amount is 60mm3 * 0.83gr/mm3 = 49.8mg.
I found the formula in the textbook for automotive engineering.
found.
1000 * effektive Leistung * spez. Consumption.
-------------------------------------------------------------- = Volume in mm3
60 * Engine speed * Fuel density * Number of cylinders
Best regards, chrigu.
Translated on 02-10-2026, 17:16.
Post14-11-2002, 18:38    Subject: Awkward Moment: A Funny Story Quote
chrigu wrote:
Hello.
Hi.
Oh man, I &$%§%(), equated weight and volume new_tomato.gif.
You are absolutely right.
Translated on 02-10-2026, 17:17.
chrigu
Post14-11-2002, 23:20    Subject: PD Motor Performance: Maximize Your Output Quote
Hello Ulf,
The question is probably not so easy to answer.
I think there's a connection to what I'm working on.
Translated on 02-10-2026, 17:18.
No new posts AFN Engine Performance Data, MJ 1998 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VTG Adjustment for VAG TDI Engines Technical Articles
No new posts DIY solution for starting engines with VP 37 Troubleshooting & Guides
No new posts PD TDI Engine Performance: Real-World Results Diesel Engine Technology
No new posts AFN Engine Performance Issues: MJ 1998 Documentation Diesel Engine Technology
No new posts TDI A4: Max. Particle Filter Temp. 170 PS Diesel Engine Technology
No new posts Overload A6 2.7 BPP P242F - Max Load Exceeded Diesel Engine Technology
