Compatible Tank Caps: 6N0 vs 1H0?
reuselkopp
Post09-03-2006, 15:11    Subject: Compatible Tank Caps: 6N0 vs 1H0? Quote
hello,
Are the two fuel senders compatible with each other? The first one is installed in an Ibiza TDI, and the second one is in a Golf 3 TDI. They look the same visually, except that one is black and the other is white.
Golf 4 Variant Modell 05, ASZ mit 330000, ERF Getriebe, mit Zwangskorken, Softwareanpassung von Alex Günther
Golf 3 Variant Modell 98, AFN mit 281000km, ASD Getriebe, VNT15 mit großer Dose, ansonsten alles Original / verkauft
Translated on 01-09-2026, 7:43.
Karma: +438 / -0   Thank you, like it!
Post10-03-2006, 5:47    Subject: Compatible Tank Caps: 6N0 vs 1H0? Quote
Unfortunately, I don't have access to the file right now. If you already have both of them and can visually confirm that they are identical except for the color, then connect a measuring device to one of them and check the values (both static and while you're moving the sensor).
I could imagine that the fuel tank design of the two vehicles is different, which might lead to the use of different fuel level sensors. However, this is just a speculation, and it could just as easily be a software issue.
Guste.
Translated on 01-09-2026, 7:44.
reuselkopp
Post10-03-2006, 8:59    Subject: Compatible Tank Caps: 6N0 vs 1H0? Quote
I don't have the two devices in front of me; I've only compared them in a picture. I need a new one, and these two are listed on E***.
Translated on 01-09-2026, 7:45.
No new posts TDI Chiptuning Kompatibel? Diesel Engine Technology
No new posts Golf 4 TDI ARL OBD2 Kompatibel ? On-Board Diagnostics (OBD)
No new posts ECU for VW Passat 35i 1Z: Replacement, Faults, Compatibility On-Board Diagnostics (OBD)
No new posts Are the air mass sensors wear and tear parts? Diesel Engine Technology
