Another AKN NW question
durnesss
Post14-03-2006, 22:52    Subject: Another AKN NW question Quote
hi
currently deciding on the fundamental question
99er AKN with 193,000 km, keep and upgrade.
or, if possible, to depart as soon as possible.
I'm actually quite satisfied with it now.
and the dealer offers for that are really bad.
But:
It was, of course, all completely new.
(Turbo, spark plugs, front suspension, FIS, LMM, hood seal.....................)
and the timing belt is also still at 27,000 km
and also consumes less than 7.5L/100
and is also freshly passed the {MOT/INSPECTION}
and I'm sure I'll also manage to fix the rear axle problem
but I can hardly believe that my investment, apparently, isn't going up.
At least the 2 levers that can be seen.
'However, they have a running track, but no groove.'
What is the chance that the others look the same?
Am I overthinking this?
Thomas
Herr Antje
Post15-03-2006, 8:48    Subject: Another AKN NW question Quote
Hello, I have decided to continue with the project. I just purchased all the parts needed for the camshaft replacement, EUR 1.500,00 including all belts, pulleys, gaskets, and water pump. Everything that goes directly into the engine (camshaft, followers, and hydraulics) is original VW, the rest is aftermarket. However, a quote from Friendly for this scope was approximately EUR 3,000-3,500!!
I am of the opinion that the engine (excluding the NW) is durable and can also run more than 300,000 km, with proper maintenance. It is important to change the oil regularly (every 30,000 km) (my car's recommendation is 50,000 km LL icon_evil.gif, which I don't consider to be regular).
I can't guarantee that you'll be spared from the NW problems. I consider checking the oil filler supports to be unreliable, and that's why everything would still be relatively under control for me, which wasn't confirmed after lifting the ZK cover. NW damage can already be seen in the performance and running culture, so there is no need to worry yet.
If you can do everything/a lot yourself, keep the box. If you have to do everything in the workshop, I think you should separate.
If you want to keep driving for a while, why don't you let your engines fire up, just to make sure everything is still working properly, then you'll immediately see the problem.
27 tkm until the timing belt replacement, meaning you have already driven 93 tkm with the timing belt. I believe that the belt should be replaced sooner (90-100 tkm) rather than driving it up to 120 tkm. I often hear about timing belt failures, and I think the V6 is particularly "susceptible". That, however, is up to each individual...
I will even perform a chip tuning after the swap to the new engine (175,000 km). Some people might definitely scratch their heads about this, especially since I want to drive my car for another 100,000 km icon_biggrin.gif
Aktuell:
- G3 VR6 '93 128 kW, MKB: AAA
christians
Post15-03-2006, 23:33    Subject: Another AKN NW question Quote
If he's performing well, you should keep him, who knows how his successor will behave. Otherwise, as Mr. Antje said, you must consider all aspects, I wouldn't wait until the engine starts to run rough, by then the rocker arms might already be worn out. NW (vehicles) can certainly last up to 300,000 km, even though some people vehemently deny this.
No new posts Sudden performance loss after restart, then okay again Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Engine starts, then immediately stalls. Model: ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AGR: Another One? Causes and Solutions Diesel Engine Technology
No new posts Schon wieder Temp Mittel Geber Diesel Engine Technology
No new posts Audi A4 1.9 TDI: Error Code 00575 - Troubleshooting On-Board Diagnostics (OBD)
No new posts Audi A4 1.9 TDI: Error Code 00575 - Troubleshooting Guide Upload
