VWGOLFIII Guest
18-11-2002, 11:39 Subject: Lip filler check: Is it safe? |
Hi.
Is it possible to check the glow plugs while they are still installed, for example, using an ohmmeter? And what should the resistance value be for a good glow plug?
Thank you, and best regards, Mark.
Translated on 24-07-2026, 17:27.
Joined: 04/12/2002 Posts: 18092 Karma: +799 / -0 Location: St.Gallen 2018 Volkswagen T6
18-11-2002, 11:57 Subject: Lip filler check: Is it safe? |
Hey, we've already discussed that; the search function is your friend.
Translated on 24-07-2026, 17:28.
Profile PM WWW Garage |
VWGOLFIII Guest
18-11-2002, 12:12 Subject: Lip filler check: Is it safe? |
Hi.
Thank you, but I can't find anything using the search function. Do you still have the link? If so, could you please send it to me?
Bertil Profi-Schrauber
18-11-2002, 12:28 Subject: Lip filler check: Is it safe? |
Translating... |
