Find plug, connector, adapter - Buy now!
alfo
Post05-05-2002, 13:47    Subject: Find plug, connector, adapter - Buy now! Quote
'I can't find the connector for the GRA. I've already disassembled half of the amplifier board. Does anyone know where it's hidden?'
ASO is a Golf 3 TDI with a 1Z engine.
Translated on 31-10-2026, 17:58.
Post05-05-2002, 15:05    Subject: GRA Connectors: Buy Now & Save! Quote
Hello Alfo,
"On my G3 1Z combination instrument, the connector was located behind the relay panel (a four-pin, flat connector). Since the cable attached to it isn't very long, it should be in the same location for you as well."
Best regards, Bertil.
Translated on 31-10-2026, 17:59.
Rudi
Post05-05-2002, 19:21    Subject: Popular Hiding Spot: Find the Best! Quote
The guys at VW also like to hide the connector behind the pedals, under the carpet (that's where it was in my '96 G3 Variant).
alfo
Post06-05-2002, 22:10    Subject: New Problem: Solutions and Analysis Quote
I found a plug, but it doesn't fit. However, it has the same color as the wires. Are there different types of plugs?
Translated on 31-10-2026, 18:00.
Post07-05-2002, 7:22    Subject: Cable Colors: A Guide to Electrical Wiring Quote
The plug doesn't directly fit the switch's connector; there's an intermediate cable needed (which you might have to build yourself, as I did).
This topic is locked, you cannot edit or reply. OBD2 Adapter Cable for VW Golf 4 Diesel Engine Technology
No new posts What kind of plug do I have? Diesel Engine Technology
No new posts Flat Pin Connectors & Housing - 10 Cent Diesel Engine Technology
No new posts ESP Connectors: 8-Pin vs. 10-Pin Diesel Engine Technology
