ARL: Set Start Date for Grants.
Nobi.k
Post31-03-2006, 17:32    Subject: ARL: Set Start Date for Grants. Quote
Today, I tried to optimize the fuel injection start timing on my Golf ARL, model year 2002. I was attempting to adjust the VAG base setting from 000 to approximately 120.
I previously had a similar experience (AJM) and it worked out great.
So, I loosened the three screws on the timing gear and rotated it in the early direction. I then checked the values using a VAG diagnostic tool, but unfortunately, no matter how much I rotated it, the value on the tool didn't change (it remained at 131).
The start date for the funding has been changed, but I can't find the new value in the master data or in the default settings.
Values only change in relation to temperature.
I used some old blueprints to help me, and I reassembled everything.
Who can explain this to me???
Greetings.
Nobi.k
Translated on 26-09-2026, 5:05.
Back to top Profile PM Email
FSEC
Post11-04-2006, 15:14    Subject: ARL: Set Start Date for Grants. Quote
What exactly did you do?
or what is the car doing now???
Translated on 26-09-2026, 5:06.
No new posts Adjusting timing and PD element for common rail diesel en... Troubleshooting & Guides
No new posts TDI Synchronization Angle: What is it? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Set Grant Start Date Diesel Engine Technology
No new posts AFB V6 TDI - When to stop fueling? Diesel Engine Technology
No new posts 1.6 TDI: Adjust Power & Injection Timing Diesel Engine Technology
This topic is locked, you cannot edit or reply. Start subsidy, model 1Z, year of manufacture 1996 Diesel Engine Technology
