unrunder Motorlauf,ESP? Diagnose per OBD -WER ANALYSIERT LOG | Posts 16+
Go to page: Previous  1, 2
robotroonie
Post26-04-2006, 19:58    Subject: Quote
After a phone call with the master mechanic of my workshop, I believe that the problems are likely caused solely by air in the vacuum line (VL) under higher loads. Therefore, I need to find a way to address this issue first.
"Could someone perhaps tell me how much fuel the VP44 injects at full load in my vehicle? It's already injecting 150 liters per hour at idle."
Translated on 24-08-2026, 4:01.
Post26-04-2006, 20:39    Subject: Quote
How about putting a transparent piece of fuel hose inside the car and giving it full throttle?
Translated on 24-08-2026, 4:02.
robotroonie
Post26-04-2006, 20:44    Subject: Quote
Initially, I had planned to use transparent PA tubing for the engine compartment, but 1. it was very inflexible (especially in cold weather), and 2. it was difficult to get a good seal.
"Before the ESP (Electrostatic Precipitator), there's a transparent section that is factory-installed. And when you accelerate, you sometimes see bubbles forming in it (but not when the system is idle). I suspect the filter head."
No new posts DIY OBD Adapter: Build Your Own Diagnostic Tool Troubleshooting & Guides
No new posts VR6 Engine Misfire: Causes & Solutions Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J Engine Noise: Diagnosis & Repair Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Blue Smoke & Rough Idle: AFN Engine Problems Diesel Engine Technology
No new posts LOG analysis Audi 2.5 AKE - uneven engine running On-Board Diagnostics (OBD)
No new posts LOG Analysis Audi 2.5 AKE - uneven engine running, VCDS-LOG Upload
No new posts Rough Engine Idle: AFN Causes & Fixes Diesel Engine Technology
