Audi A2 to A6, Engine Area, Generosity Policy (Solution)
Michael II
Post07-05-2002, 20:36    Subject: Audi A2 to A6, Engine Area, Generosity Policy Quote
(KM figures in thousands)
Piston eater
Types: 4+
KM 100 / Months 48 / Salary 100% Materials 100%
Type 8+
KM 100 / Months 60 / Salary 50% Materials 50%
Piston rings, high oil consumption
Types: 4+
KM 100 / Months 24 / Salary 100% Materials 100%
KM 120 / Months 36 / Wage 75% Material 50%
KM 150 / Months 48 / Wage 75% Material 50%
Crankshaft Seal
Side-to-side leakage
Types: 4+
Types: 8+
Cam Belt Tensioner
Types 4+
Types: 8D+
KM 120 / Months 36 / Salary 100% Materials 75%
KM 150 / Months 48 / Salary 50% Materials 50%
Timing belt is running unevenly.
severe wear on the
Front edge
Types: 4B+ TDI, 8D+ TDI, AKN-/AFB Engine 2.5 l V6
KM 120 / Months 36 / Salary 100% Materials 100%
Timing belt snapped (before)
(Interval of change)
Types 4+
KM 120 / Months 48 / Salary 100% Materials 100%
Types: 8+
KM 120 / Months 60 / Salary 50% Materials 50%
Timing belt tensioner, tightened.
Stays
Types: 4A+, 8D+
KM 120 / Months 60 / Salary 100% Materials 100%
Timing belt damaged (before)
Types: 4A+, 8C+, 8D+
Timing belt is running sideways.
wears out
Types: 8C--X+ TDI
KM 90 / Months 36 / Salary 100% Materials 100%
Types: 8D--F+ TDI, 8G--A+ TDI, 4A--X+ TDI, 4B--Y+ TDI
KM 90 / Months 48 / Salary 50% Materials 50%
Coolant/Oil Leak
Types: 4+
KM 100 / Months 36 / Salary 100% Materials 100%
Types: 8+
KM 150 / Months 48 / Wage 50% Material 100%
Flush the cooling system until 2000.
Types: 4+, 8+
Months 60 / Salary 100% Material 100%
Whirlpool chamber broken
Types 4+
Type 8+
KM 150 / Months 48 / Wage 75% Material 75%
KM 200 / Months 60 / Salary 50% Materials 50%
Oil pump leaking, no oil pressure.
Types: 4+
Types: 8+
KM 120 / Months 48 / Salary 50% Materials 50%
Coolant pump
Types: 4A+
KM 75 / Months 24 / Wage 100% Material 100%
Types: 4B+, 8+
KM 100 / Months 36 / Wage 70% Material 70%
Spark plugs wet/carboned
Types: 8D+. 4B+
KM 200 / Months 36 / Salary 100% Materials 100%
Turbocharger leaking
Types: 4+
Types: 8+
KM 150 / Months 36 / Salary 100% Materials 75%
Fuel pump not functioning correctly.
Performance issues, stuttering,
bad starting, etc.
Types: 4+ TDI
Months 36 / Salary 100% Material 100%
Types: 8+ TDI
Fuel loss outside
Cylinder head
4B+, 8D+
KM 150 / Months 48 / Salary 100% Materials 100%
Fuel injectors, short, hard
Malfunctions at higher
RPM and Acceleration
4A+ TDI, 8+ TDI
KM 150 / Months 36 / Salary 100% / Materials 100%
Gradually decreasing
Engine Power
4B+ TDI V6, 8D+ TDI V6 AKN-/AFB Engine
Cold start problems
Types: 8D2054
Exhaust manifold cracked
Types: 4+
Types: 8+
KM 200 / Months 48 / Salary 50% Materials 50%
Monolith in the Catalyst
merged, disintegrated
Types: 4+
KM 80 / Months 24 / Salary 100% Materials 100%
Types: 8+
KM 100 / Months 36 / Wage 50% Materials 100%
KM 120 / Months 48 / Salary 0% Materials 50%
Timing belt tensioner breaks,
Timing belt snapped.
Types: 8D..X8, 8D..Y8
KM 200 / Months 60 / Salary 100% Materials 100%
Ventilation system leaking
Types: 4+
KM 150 / Months 60 / Salary 50% / Materials 50%
Heat exchanger leaking
Types: 8D+
KM 150 / Months 60 / Salary 100% / Materials 100%
Klimakompressor (R134a) is making a loud noise,
difficult
Types: 4+
KM 100 / Months 24 / Salary 100% / Materials 100%
Types: 8+
KM 120 / Months 36 / Wage 50% Material 100%
KM 150 / Months 48 / Material 100%
Evaporator leaking
Types: 4+
KM 100 / Months 36 / Salary 100% / Materials 100%
Types: 8+
KM 150 / Months 60 / Salary 50% / Materials 100%
Tschüss
Michael II
Ratings - Audi A2 to A6, Engine Area, Generosity Policy
Average rating: 4.00 - worst rating: 4 - best rating: 4 - number of ratings: 1 - View ratings
No new posts Audi A2 to A6 goodwill policy, body section Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A2 to A6, Gearbox Area, Customer Goodwill Policy Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A2 to A6 Good Will Policy, Electrical System Area Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW Good Will Policy: Interesting Insights Transmission, Chassis, Body & Interior
No new posts 1Z Motor Audi 80 B4: Make the engine more fuel-efficient Diesel Engine Technology
No new posts Sunroof Noises: Causes and Solutions Transmission, Chassis, Body & Interior
No new posts Audi A3 TDI: Rough Running at 1900-2300 RPM Diesel Engine Technology
