Temperature/Pressure Sensor for Manual Climate Control
brezelmann01
Karma: +75 / -0   Thank you, like it!
Post24-11-2002, 11:28    Subject: Temperature/Pressure Sensor for Manual Climate Control Quote
Hello!
I have a manual air conditioning system in my 2000 Polo (unfortunately). Unfortunately, it's also not diagnosable, which means I can't read the current pressures with VAG-COM. However, there's a combined pressure/temperature sensor installed in the air conditioning line, behind the front bumper (3-pin). Can someone provide me with the corresponding resistance values for specific pressures (and, of course, the temperature value)?
Thank you.
brezelmann01
No new posts Troubleshooting manual air conditioning system, Volkswage... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A3 TDI AC Fan - 1st Speed Problem Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Manual climate control > Map-based cooling? Transmission, Chassis, Body & Interior
No new posts Oil Temperature: How to Check & Fix Diesel Engine Technology
No new posts AFN Temp. Problem? On-Board Diagnostics (OBD)
No new posts Temperature Display: Check & Troubleshooting Diesel Engine Technology
