Flat Pin Connectors & Housing - 10 Cent
suggermilk
Post23-11-2002, 2:29    Subject: Flat Pin Connectors & Housing - 10 Cent Quote
Where can I get individual connectors without cables for the pump cable?
One of the plugs with cables is working fine, but the other one is broken.
Maybe someone knows where to find individual plugs.
Translated on 03-10-2026, 14:25.
Rudi
Post24-11-2002, 16:17    Subject: Flat Pin Connectors & Housing - 10 Cent Quote
You can also get the individual connectors at 'Freundlichen,' but you might have to do some digging (since the pre-wired ones can't be used for everything).
The contacts are from AMP (which is now part of Tyco) and are marketed under the name 'Timer Contact' (e.g., MicroTimer2 - such as LMM - or JuniorPowerTimer - such as ESP-).
Best regards, Rudi.
Translated on 03-10-2026, 14:26.
suggermilk
Post24-11-2002, 20:08    Subject: Flat Pin Connectors & Housing - 10 Cent Quote
Where can I get the contact information for AMP?
Homepage or order shipment?
Maybe you could tell me where I can get them.
I've already been to three dentists, and they were all nice, but unfortunately, nothing worked, even with drilling.
OLI.
Translated on 03-10-2026, 14:27.
Rudi
Post24-11-2002, 20:33    Subject: Flat Pin Connectors & Housing - 10 Cent Quote
Unfortunately, I don't have those connectors in stock, but RS or Farnell might have them in their product range. Otherwise, you might have to search for them on Tyco's (rather confusing) website.
The ESP connector socket contact, with a wire gauge of (1-2.5mm^2), is part number 929938-1 and can be found on the following page:
http://catalog.tycoelectronics.com/TE/bin/TE.Connect?C=1&PN=929938-1&M=BYPN&LG=1&I=13&button.x=55&button.y=22
(Counter Contact 1-963749-1).
Best regards, Rudi.
Translated on 03-10-2026, 14:28.
No new posts Find plug, connector, adapter - Buy now! Diesel Engine Technology
No new posts What kind of plug do I have? Diesel Engine Technology
No new posts ESP Connectors: 8-Pin vs. 10-Pin Diesel Engine Technology
This topic is locked, you cannot edit or reply. OBD2 Adapter Cable for VW Golf 4 Diesel Engine Technology
