Hopa Digital Divo: User Manual & Guide
New Topic 🔒 Locked 🔗 ⭐ 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
johho
Post25-05-2006, 13:48    Subject: Hopa Digital Divo: User Manual & Guide Quote
Hello everyone!
I need the troubleshooting guide for a Hopa Digital Divo control unit.
Unfortunately, I can no longer find the original text.
I'm specifically interested in the 5 small LEDs that indicate operating statuses on the control unit. Does anyone have a manual for this, or could you scan it and send it to me? Alternatively, could someone tell me what each of the individual LEDs indicates?
That would be AMAZING!
John.
Hello everyone!
Please provide the German text you would like me to translate into English. I will then give you only the translation, without any explanations.
Johannes Hofmann, vehicle identification number (VIN) 3B5325, engine code MJ2000, power output PA, emissions class AHH/EAB/5S/HX/7D/7D, engine type 1.9 TDI, engine power 82 kW (Hopa control unit), original engine power 66 kW.
Johannes Hofmann
Translated on 24-07-2026, 18:53.
tdi-schrauber
Post27-05-2006, 11:39    Subject: Hopa Digital Divo: User Manual & Guide Quote
Hello!
Hopa itself will certainly be able to help you further.
mailto:[email protected]
BYE
TDI mechanics.
Translated on 24-07-2026, 18:55.
Post27-05-2006, 12:14    Subject: Hopa Digital Divo: User Manual & Guide Quote
Oh man. When I read such nonsensical garbage like on the Hopa website, it just makes me sick. That's why I removed the link from the post, because I don't want to support sellers who engage in advertising with blatant falsehoods and also profit from those links.
More arguments in favor of biofuels, as digitalDIVO systems are capable of compensating for the disadvantages of biodiesel (biofuel is cheaper compared to mineral fuels)!
Nonsense. The energy content of biodiesel remains the same with or without the "proletariat box." Similarly, the sealing issues persist.
The installation of digitalDIVO does not require any intervention in the vehicle's or engine's control electronics. No parts are removed or replaced. Traditional tuning usually increases fuel consumption. Vehicles optimized with digitalDIVO typically consume less fuel, but never more than before. Traditional tuning often worsens exhaust emissions. This is not the case with digitalDIVO.
Absolutely ridiculous nonsense.
See:
Boost pressure adjustment.
The digitalDIVO is able to precisely adjust the boost pressure as needed.
More bullshit. Anyone who looks at the wiring and what's inside the bulb will realize that something isn't right.
If the car drives normally without the battery pack, it would probably be best to use the battery pack as a paperweight or recycle it as electronic waste.
I've used a similar device from another manufacturer for quite some time now, and it does exactly the same thing. It has all the advantages and disadvantages that come with using a box-type device, regardless of the brand name on it or whether it's housed in a fancy aluminum casing with flashing LEDs or simply encased in plain black plastic.
But anyone who uses such unprofessional advertising on their websites can only be warned against. icon_exclaim.gif
Translated on 24-07-2026, 18:58.
mullemaus
Post27-05-2006, 19:04    Subject: Hopa Digital Divo: User Manual & Guide Quote
Therefore, I would advocate for a lock icon_wink.gif. Support can be provided by Hopa; those who want something proper can use the shop button above. icon_wink.gif
Translated on 24-07-2026, 19:01.
Post27-05-2006, 19:31    Subject: Hopa Digital Divo: User Manual & Guide Quote
Good idea... Thanks to such tasteless advertising, I have to deal with a huge number of extremely stupid requests every day, so I don't need to provide support for this company on top of that.
It's a shame that most people believe anything they hear as long as it's repeated often enough or packaged attractively. Well, not much has really changed since the days of "bread and circuses."
No new posts Keyless Entry Installation Guide by IN.PRO Troubleshooting & Guides
No new posts Hopa Divo VP37 Installation for VW Golf 3 TDI AHU Diesel Engine Technology
No new posts Topic: LMM at Hopa Diesel Engine Technology
No new posts Hopa Auxiliary Control Unit: Installation Guide Electrical Systems, Vehicle Electronics, Multimedia
No new posts Hopa Plug Installation Help Diesel Engine Technology
