Notlauf nach dem Kaltstart??!? | Posts 16+
Go to page: Previous  1, 2
DocSnydor
Post25-11-2002, 18:55    Subject: Quote
@ampac
If you still want to go through with this scheme, here's a small tip:
You'll have better access from below; simply remove the plastic undertray (4 Allen screws in the wheel wells, 2-3 hex screws).
I also have a [type of item], but it's a 1Z model, and the rod should be in roughly the same position! Maybe this will help...
Translated on 06-09-2026, 22:57.
Arno
Post25-11-2002, 22:58    Subject: Quote
@DocSnydor
You are right, the frame and can are almost exactly the same (my father has a 1Z). However, the plastic tray really becomes annoying over time because you have to remove it for even the smallest tasks. This bothers me the most because I don't have a pit or lift. I only have small ramps to get the vehicle a little higher in the front icon_sad.gif. But now, after the heating up on the track, I would say that the VTG is working noticeably better again (the question is, for how long), and the turbo misfires are also almost gone icon_biggrin.gif.
By the way: I went to the mechanic today for an X-ray of the ESDs (Electronic Stability Devices), and he told me that they haven't done that in a long time, but instead just replace them completely. He only referred me to the Bosch service center, which still does that (thankfully icon_lol.gif).
Arnold.
Translated on 06-09-2026, 22:59.
zzzZZ
Post26-11-2002, 8:06    Subject: Quote
if you remember, I would be interested to know exactly what you used to smear with the paste.
Hello Ulf,
Luckily, in my case, it was only the adjustment lever or the joint, because that's all I lubricated.
René K.
Translated on 06-09-2026, 23:00.
No new posts Audi A4 B7/8E 1.8T BFB - Shaking/Vibration after cold start Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Golf 1J, from week 48/98, Clattering noise afte... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Lupo 6X1 MJ 2001, Clattering noises after cold start Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts TDI Cold Start: Emergency Mode Troubleshooting On-Board Diagnostics (OBD)
No new posts Blue smoke on V6 cold start - cause? Diesel Engine Technology
No new posts Blue smoke on cold start: 1.9 PD-TDI Diesel Engine Technology
No new posts Loader Piping After Cold Start Diesel Engine Technology
