Maximus1604
Joined: 05/20/2006 Posts: 3 Karma: +0 / -0 Location: Einhausen
20-05-2006, 17:16 Subject: Engine Idle High: 1250 RPM, Low Power, 6 Errors |
Hello everyone,
I own a VW Passat, model year 1994, with a 1.9 TDI engine and a 1Z engine code.
It suddenly idles at 1250 RPM and has power loss throughout the entire RPM range.
I was able to read the following error codes from the control unit.
00527 Sensor for intake air temperature (g27) 30-00: Open circuit/Short circuit to positive.
00777 Accelerator pedal position (g79) 27-00, implausible signal.
00522 Coolant temperature sensor (g62).
00539 Fuel temperature sensor (G81) - Open circuit/Short circuit after positive terminal.
00741 Brake pedal monitoring - 27-00, implausible signal.
00553 Air mass sensor (g70) 28-00 Short circuit to positive.
The error message about the mass airflow sensor appeared when I was trying to clear the memory.
Since the car was parked outside that night, I suspected damage caused by a weasel.
At first glance, I couldn't see anything.
With so many errors suddenly appearing overnight, it occurred to me that...
"that the control unit is defective, as some parts are showing errors."
were replaced. For example, the mass airflow sensor, the intake air temperature sensor, and the electronic stability program (ESP).
Can someone tell me if my assumption is correct (plural)?
Or perhaps another idea, before I embark on a massive cable harness measurement project.
"to carry out" or "to perform" or "to execute".
Thank you in advance.
Best regards, Maximus1604.
Translated on 02-10-2026, 9:17.
leo_b Blaumann
Joined: 02/03/2005 Posts: 145 Karma: +1 / -0 Location: Hamburg
20-05-2006, 17:31 Subject: Phone? Could it be a mobile phone! |
hi,
As silly as it sounds, a mobile phone could be the cause of such phenomena!
This actually happened to me about 5 years ago!
While I was on a trip in the countryside, I received a call on my mobile phone.
It was in the T4, on the dashboard.
At that very moment, the preheating light started to blink.
So, I called Volkswagen, completely unaware at the time.
When they checked the storage device with the reader, various errors were detected, but they didn't seem to be related to each other in any meaningful way.
Error memory cleared and driving continued.
So, why couldn't a strong electromagnetic field be the cause in your case as well?
best regards, leo Mein Bussi: Trapo, 7/1999, Kombi L, 8 Sitze, Indianblau, 88PS (65kW) TDI, MKB: AJT, GKB: DUJ, mit kleinem LLK, 340000km
Translated on 02-10-2026, 9:21.
Maximus1604
20-05-2006, 18:39 Subject: Engine Idle High: 1250 RPM, Low Power, 6 Errors |
Thank you for your reply, but the errors cannot be deleted.
They remain in memory and have not been accessed.
Regards, Maximus.
Translated on 02-10-2026, 9:22.
Bertil Profi-Schrauber
dieselschrauber likes this. |
20-05-2006, 18:52 Subject: Engine Idle High: 1250 RPM, Low Power, 6 Errors |
Wow, the search function is really cool...
Okay, I'm ready. Please provide the German text you want me to translate. Gruß Bertil
Herr Antje Schrauber
Joined: 01/18/2006 Posts: 1547 Karma: +7 / -0 Location: Nahe Tübingen
20-05-2006, 21:48 Subject: Phone Found? Identify Your Lost Mobile Device. |
leo_b wrote: | hi,
EMC measurements should not have been performed only recently. That's quite something  . Aktuell:
- G3 VR6 '93 128 kW, MKB: AAA
Translated on 02-10-2026, 9:23.
Nebelwerfer_TDI Guest
22-05-2006, 9:04 Subject: Engine Idle High: 1250 RPM, Low Power, 6 Errors |
Or water ingress into the control unit  .
Translated on 02-10-2026, 9:24.
22-05-2006, 15:57 Subject: Engine Idle High: 1250 RPM, Low Power, 6 Errors |
Nebelwerfer_TDI wrote: | Or water ingress into the control unit  |
It could also be a good thing. In any case, the ground connection for the sensors is missing (short circuit to the positive terminal). Gruß Bertil
Maximus1604
22-05-2006, 18:03 Subject: Engine Idle High: 1250 RPM, Low Power, 6 Errors |
Hi everyone,
First of all, thank you for the answers.
Okay, so today I'm working with individual components (e.g., mass airflow sensor, fuel temperature sensor, etc.).
Measured and checked the wiring for continuity, no errors found.
It doesn't seem to be water, otherwise the errors would have been cleared by now.
I couldn't find anything on the circuit board of the control unit either.
Unfortunately, it seems like the problem lies with the control unit. The VW dealer wants 1047 euros to fix it.
"I'm looking for one of those. Does anyone happen to know of any dealers where I can get it for a cheaper price? The ones I know are asking 599, which is okay, but unfortunately, they don't have any in stock."
in stock.
Regards, Maximus.
Translated on 02-10-2026, 9:25.
22-05-2006, 18:54 Subject: Engine Idle High: 1250 RPM, Low Power, 6 Errors |
Before you throw away the control unit, you can send it to me. I can take a look and see what can be done and whether it can be repaired.
Translated on 02-10-2026, 9:27.
Profile PM WWW Garage |
vagtuning Guest
24-05-2006, 18:45 Subject: Engine Idle High: 1250 RPM, Low Power, 6 Errors |
What is the part number of the faulty control unit?
Dj Ninja Blaumann
07-06-2006, 3:01 Subject: Engine Idle High: 1250 RPM, Low Power, 6 Errors |
Try measuring the ground connection in the engine wiring harness first. A broken wire there could have the same effect as a burnt-out circuit.
Kosta Blaumann
Joined: 06/27/2006 Posts: 16 Karma: +1 / -0 Location: Potsdam
27-06-2006, 11:31 Subject: Engine Idle High: 1250 RPM, Low Power, 6 Errors |
Hello!
Have you gotten any results from the control unit yet?
I just have a Sharan TDI with a 1Z engine from 1996, and it's exhibiting the exact same symptoms.
I've been working on this thing for three days now. My last resort is still the control unit.
Do you need to register a new or used car with the immobilizer system?
I would appreciate any answers.
0172/3287974
or [email protected]
Best regards, Rocco.
Translated on 02-10-2026, 9:28.
Kosta Blaumann
28-06-2006, 11:35 Subject: Problem Solved: Quick Fixes & Solutions |
The problem here, again, was a short circuit in the circuit board within the control unit.
Bridge soldered, error cleared, all good.
What still worries me is: What caused the circuit board trace to fail?
Short circuit in the wiring harness of the tailgate, possibly, or the brake light switch, or both?
I'm definitely very glad that the thing is working again  .
Translated on 02-10-2026, 9:29.
28-06-2006, 11:43 Subject: Engine Idle High: 1250 RPM, Low Power, 6 Errors |
I'm definitely glad that the thing is working again .
Did you, or did any of your employees, cause the errors?
Translated on 02-10-2026, 9:30.
