98'AFN 8-ofor the 10-pin pump connector?
Steffen
Post28-11-2002, 21:23    Subject: 98'AFN 8-ofor the 10-pin pump connector? Quote
A friend of mine has a 1998 Ibiza AFN and wants to buy a Powerbox (10-pole) on eBay. However, we can't check the pins right now because the car isn't here. Who can help? Does @Ulf have a 10-pole pump connector for your Golf?
Rudi
Post28-11-2002, 21:53    Subject: 98'AFN 8-ofor the 10-pin pump connector? Quote
I can't say for certain, but an Ibiza model year '98 should still have the 8-pin connector.
But it wouldn't be that dramatic either, because the contacts in the connectors are the same, and with a little tinkering (while carefully destroying the plastic housing), you can get them out.
New plastic housings (pin and socket) cost a total of 5-10 EUR.
Share numbers and pin configurations for both connectors were just posted here in the forum.
Best regards, Rudi
Post29-11-2002, 21:51    Subject: Re: 98'AFN 8-o 10-pin pump connector? Quote
Steffen wrote:
@Ulf, does your golf have a 10-pole pump connector?
Hi Steffen
My pump is 8 + 3 pole.
I believe that all AFN and 1Z have this connection.
10-pole engines are mainly found in newer VP engines, such as AHF, ALH, and ASV.
No new posts T4 2,5 ACV Ignition Lock or MSTG General Tips
No new posts Diesel vs. Gasoline: Cost Comparison Technical Articles
No new posts Tuning comparison: Chip vs. Powerbox Technical Articles
No new posts Pump Connector Part Number: Find Yours Now! Diesel Engine Technology
No new posts Pinbelegung im Pumpenstecker zur VP37 Diesel Engine Technology
No new posts Motor läuft ohne Pumpenstecker... Diesel Engine Technology
No new posts S3 or S4 seats in an Audi 80 or other sports seats? Transmission, Chassis, Body & Interior
