Golf 4 Diagnostic Adapter: Which Version?
eike
Post01-12-2002, 21:28    Subject: Golf 4 Diagnostic Adapter: Which Version? Quote
Hey fellow mechanics,
Which of the three versions of the diagnostic adapter would you recommend for a Volkswagen Golf 4? The simplest version, the extended version from Ulf, or the one with the MAX232 chip from Maik? Which one works best and most reliably in the G4?
Unfortunately, I don't have time for my own experiments.
Thank you and best regards.
Eike.
Translated on 24-08-2026, 16:50.
Maik
Post02-12-2002, 9:44    Subject: Golf 4 Diagnostic Adapter: Which Version? Quote
Hi Eike,
'On my Golf 3 TDI, manufactured in 1994, even the cheapest adapter (connected to a standard PC) worked, although I only had problems because my laptop didn't recognize the adapter (due to issues with the interface levels). That's why I also have a version using the MAX232 chip to avoid this problem.'
Maik.
Translated on 24-08-2026, 16:51.
AndyO
Post02-12-2002, 20:24    Subject: VAG-COM Adapter: Diagnose & Tuning Quote
From the perspective of an electrical engineer, version 2 is preferable (due to its use of readily available components and better pulse shaping). The circuit involves potential isolation with adjustable pulse amplitudes. There's not much that can go wrong here. Unfortunately, another test is pending because the OBD II connector is missing.
Translated on 24-08-2026, 16:52.
No new posts Bosch ESP 5.3: Error Codes & Troubleshooting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Error codes and possible causes for Bosch ABS Version 5.0... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Error codes and possible causes for Bosch ABS Version 5.3... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ACV engine control unit, which version? Diesel Engine Technology
This topic is locked, you cannot edit or reply. VAG-COM: Old Versions & Downloads On-Board Diagnostics (OBD)
No new posts VCDS 3-Fin Version On-Board Diagnostics (OBD)
No new posts Which version do I need? On-Board Diagnostics (OBD)
