Door lock broken.
rivo
Post03-12-2002, 21:07    Subject: Door lock broken. Quote
I am having problems with {the door lock} on the driver's side.
Passat, manufactured in 1997
Can rotate in all directions without resistance... without success. However, the central locking system functions perfectly from the passenger door.
Is it just a minor issue, or is the problem more serious?
Maybe someone can give me a tip on where I should start looking for the problem, before I scrap the door panel!
Thank you!
No new posts Door Lock Malfunction: A6 4B Documentary Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Interior Light Switch in Door Lock - Defective Transmission, Chassis, Body & Interior
No new posts Door Lock, Microswitch, or Grounding Issue? Transmission, Chassis, Body & Interior
No new posts The door lock no longer works in the cold. Transmission, Chassis, Body & Interior
