Cisco Guest
03-12-2002, 22:47 Subject: 110hp injectors in a 1Z 90hp engine?? |
I heard that the threads on the fuel injectors are the same.
Will I get any performance benefits if I install them? I currently have a chip installed in my car. It has 175,000 km on the odometer.
Sure, here's the translation:
'Thank you in advance.'
Cisco.
Bertil Profi-Schrauber
03-12-2002, 23:38 Subject: 110hp injectors in a 1Z 90hp engine?? |
The fuel injectors in the VP TDI engines from VAG are not screwed in, but rather inserted and then secured with a bracket.
I've heard in various reports that injectors from other TDIs are sometimes used. I don't have any experience with that. Gruß Bertil
Stefan Guest
05-12-2002, 9:40 Subject: 110hp injectors in a 1Z 90hp engine?? |
Yes, it noticeably increases performance.
