Looking for login code for comfort control unit
Duseltier
Post08-08-2006, 13:00    Subject: Looking for login code for comfort control unit Quote
Hello everyone,
I have a Passat manufactured in 1998 with the following comfort control unit:
3 B0 959 796 L
I would like to modify the locking message (channel 06 and channel 0icon_cool.gif.
However, in the VAG-COM system, both channels are indicated as unavailable.
I think the control unit needs a code.
Does anyone have this code or a suitable label file for this control unit? (It is also not included in version 5.1.2.)
Sure, here's the translation:
'I would also like to receive it via private message.'
Thank you in advance.
God bless.
Translated on 19-07-2026, 20:52.
Ross-Tech-Support
Post08-08-2006, 13:30    Subject: Subject: Request for login code for comfort control unit Quote
Duseltier wrote:
However, in the VAG-COM system, both channels are marked as unavailable.
Because they are not yet included in this control unit.
Duseltier wrote:
I think that the control unit needs a code.
Logins are often overrated; not every problem can be solved with a login, and frequently, as in this case, the functions simply aren't designed to work that way.
Okay, I understand. Please provide the German text you want me to translate into English. I will only provide the translation.
Code:
VAG-COM > Anwendungen > Steuergerät Abbild
Adresse: 46
Funktion: Messwerte
Ausgabe: Labelvorlage
Start
You will find the file named "46-3B0-959-796-L.PLB" in the directory "/VAG-COM/Logs/". Please send this file to me via email.
Translated on 19-07-2026, 20:54.
No new posts Login Codes TDI / VAG Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts HEX-V2: Login failed Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Login Code for Comfort Control Unit Diesel Engine Technology
No new posts Login Code for Comfort Control Unit in Skoda Octavia On-Board Diagnostics (OBD)
This topic is locked, you cannot edit or reply. 7-Digit Login Code: Find & Generate Now On-Board Diagnostics (OBD)
No new posts ECU Login Code: How to Find & Use On-Board Diagnostics (OBD)
