1Z Problems: Another One! (SEO Optimized)
haehnlein
Post05-12-2002, 20:14    Subject: 1Z Problems: Another One! (SEO Optimized) Quote
Hi fellow DIY enthusiasts!
This time, it happened to a friend's A4 TDI 1Z, manufactured in 1995, with 220,000 km on the odometer.
Shortly after starting (1-3 seconds), the engine shuts off. It doesn't matter if the engine is cold or warm. The problem doesn't always occur, and there are no issues while driving (-> full power). Sometimes it takes 4 attempts to get the engine started. Once the engine runs for longer than 5 seconds, it doesn't shut off again.
Was könnte das sein?? Wegfahrsperre? NBF is new!!
I have this nagging feeling that soon, the three of us – my friends, my father, and I – will be frequenting this place icon_redface.gif icon_redface.gif.
Thank you in advance icon_exclaim.gif icon_exclaim.gif icon_exclaim.gif.
Best regards, Christian.
Translated on 11-10-2026, 16:19.
jens712001
Post05-12-2002, 21:32    Subject: 1Z Problems: Another One! (SEO Optimized) Quote
That definitely sounds like an immobilizer problem. I would try disconnecting and reconnecting the connector at the reading coil on the ignition switch a few times; that should fix it. However, you'll need to remove the airbag, steering wheel, etc. to do that!
Translated on 11-10-2026, 16:20.
Michael II
Post05-12-2002, 22:56    Subject: 1Z Problems: Another One! (SEO Optimized) Quote
Before dismantling anything, I would first read the error codes. This might give us a more precise indication of the problem.
Tschüss
Michael II
haehnlein
Post05-12-2002, 23:28    Subject: 1Z Problems: Another One! (SEO Optimized) Quote
Hi everyone!
Thank you for the quick responses!!! Ulf's adapter is not finished yet, and then... That sounds like a common problem icon_eek.gif.
Translated on 11-10-2026, 16:21.
Post06-12-2002, 15:41    Subject: 1Z Problem: Another Issue! Quote
haehnlein wrote:
Shortly after starting (1-3 seconds), the engine shuts off. It doesn't matter if the engine is cold or warm. The problem doesn't always occur, and there are no issues while driving (-> full power). Sometimes, it takes 4 attempts to get the engine started. If the engine runs for longer than 5 seconds, it won't shut off again.
Hi Christian,
If the engine always starts without hesitation (no signs of trouble) and then immediately stalls from a smooth, stable idle, as if the key was just turned, it is most likely due to the immobilizer system.
However, if it sounds "strange" before it stops (e.g., a rough idle, unusually hard or soft running, etc.), the problem is likely elsewhere (e.g., fuel supply issues, a stuck valve, or resistance in its line...).
Translated on 11-10-2026, 16:22.
No new posts Sudden performance loss after restart, then okay again Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Engine starts, then immediately stalls. Model: ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Problem with electricity. Auxiliary heater (G6 GTD) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Diagnostic Interface Issues: Troubleshooting Guide Diesel Engine Technology
No new posts Fixed Issue, New Problem Arises Diesel Engine Technology
No new posts LMM: Another Instance? Diesel Engine Technology
No new posts GRA in B4: Another Case? Diesel Engine Technology
