LMM Replacement: When to Change (mg/h)
benje2
Post31-08-2006, 10:45    Subject: LMM Replacement: When to Change (mg/h) Quote
My AWX (96kW TDI) is producing approximately 980-1000 mg/h of air mass. When would you recommend replacing it?
P.S.: I've already tried cleaning it, and that's all I'm going to do.
Translated on 20-08-2026, 3:41.
Herr Antje
Post31-08-2006, 11:07    Subject: LMM Replacement: When to Change (mg/h) Quote
I would swap it out if it's no longer performing well, or at the latest when the soot limit is reached. Your stated value doesn't tell me anything; you can compare "should" and "is" yourself.
Aktuell:
- G3 VR6 '93 128 kW, MKB: AAA
Translated on 20-08-2026, 3:42.
mullemaus
Post31-08-2006, 13:01    Subject: LMM Replacement: When to Change (mg/h) Quote
The limit (according to VW) is 850mg/h, which occurs at approximately 3000 RPM in 3rd gear with full throttle. Cleaning the 'weak' mass airflow sensor (MAF sensor) can help somewhat, but 'tuning' it by drilling a small hole provides more improvement. See technical articles. When dealing with these values, start with a relatively small hole and compare the readings later during a test drive icon_wink.gif.
Translated on 20-08-2026, 3:43.
benje2
Post31-08-2006, 13:53    Subject: LMM Replacement: When to Change (mg/h) Quote
The performance loss is happening "gradually"; I don't notice anything subjectively, but I feel it when comparing it to my friends' devices. *gg* There's no noticeable stuttering or direct drop in performance in the traditional sense.
No new posts P0236 - Turbocharger Overboost Condition - Bank 1 Sensor 'A' Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Glow Plug Module Replacement - Workshop Special Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Swap seat with side airbag for a Recaro seat Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ATF: When to change? Should you? Diesel Engine Technology
No new posts LMM Value Too High? Troubleshooting Guide. On-Board Diagnostics (OBD)
No new posts AHU Start-up Value: Find out the initial value. Diesel Engine Technology
No new posts Start of AEL funding - Early value maximization? Diesel Engine Technology
