Golf 4 TDI: Read Oil Temperature via Diagnostics
pa-mm6
Karma: +1 / -1   Thank you, like it!
Post05-09-2006, 21:15    Subject: Golf 4 TDI: Read Oil Temperature via Diagnostics Quote
Hello.
Is it possible to read the oil temperature via diagnostics? If so, which channel can I find it in? The sensor is installed.
"MDg" translates to "Maryland" in English.
Audi SQ5 8R Cvub
Translated on 25-08-2026, 3:24.
Back to top Profile PM Email
BM
Avatar-BM
Post05-09-2006, 21:44    Subject: Golf 4 TDI: Read Oil Temperature via Diagnostics Quote
hi
According to my information: STG01, Block7.
Fuel temperature.
2. Oil temperature.
3. Intake air temperature.
4. Coolant temperature.
3B5 AJM
Translated on 25-08-2026, 3:25.
pa-mm6
Post05-09-2006, 21:48    Subject: Golf 4 TDI: Read Oil Temperature via Diagnostics Quote
Hello.
"Thanks! I'll give it a try tomorrow."
"MFG" stands for "Mit freundlichen Grüßen," which translates to "Sincerely" or "Best regards" in English. It is a common way to end a formal letter or email.
Audi SQ5 8R Cvub
Translated on 25-08-2026, 3:26.
No new posts DIY OBD Adapter: Build Your Own Diagnostic Tool Troubleshooting & Guides
No new posts Eberspächer Heater Diagnostics: Troubleshooting Guide Troubleshooting & Guides
No new posts Webasto Heater Diagnosis: Retrofit Systems Troubleshooting & Guides
No new posts Reading 1.2 TSI (CBZB) oil temperature with ScanGauge Gasoline Engine Technology
No new posts Golf 6 BiFuel: Gas ECU Diagnostics On-Board Diagnostics (OBD)
No new posts Golf IV/Audi A4 Diagnostic Interface On-Board Diagnostics (OBD)
No new posts Nozzle Heater Check: Golf 4 Diagnostics On-Board Diagnostics (OBD)
