Ulf's Draft Calculation Tool - Loading Test
ttns4
Post06-12-2002, 14:08    Subject: Ulf's Draft Calculation Tool - Loading Test Quote
Hello, I'd like to download the latest version of the Ulf's ventilation calculator, but either I'm too stupid, or something's wrong with my eyes.
Where and how can I get it? (I wanted to download it briefly in the store new_shocked.gif).
Thorsten.
Post06-12-2002, 14:22    Subject: Ulf's Draft Calculation Tool - Loading Test Quote
Okay, so, clicking the link should be enough; then Excel with the calculator will open in the right frame.
Do you even have Excel or StarOffice?
It works great for me.
haehnlein
Post06-12-2002, 16:08    Subject: Ulf's Draft Calculation Tool - Loading Test Quote
Hi!
My Netscape 7.0+doesn't open Excel either! But Internet Explorer does (->I still use Netscape as often as possible to avoid supporting Microsoft icon_wink.gif). Netscape sometimes experiences JavaScript issues with the website www.dieselschrauber.de.
Best regards, Christian.
Post06-12-2002, 16:39    Subject: Ulf's Draft Calculation Tool - Loading Test Quote
haehnlein wrote:
Netscape sometimes has JavaScript problems with www.dieselschrauber.de.
Okay, my development computer at home uses Netscape 6.2.1 for the website, and there are no problems with JavaScript on that system.
Can you understand how and under what circumstances the problem occurs?
With Netscape, the spreadsheet will only open if the settings are correct, meaning that the file type 'xls' must be associated with a suitable spreadsheet program.
If necessary, you can also save the file and open it manually outside of Netscape.
haehnlein
Post06-12-2002, 17:47    Subject: Ulf's Draft Calculation Tool - Loading Test Quote
Rainer K. wrote:
hm, my development computer at home, which I use for the website, runs Netscape 6.2.1, and there are no problems with JavaScript on it
Hi Rainer!
"Until yesterday, I was having a problem with the small "back to homepage" window. With Netscape 7.0, I couldn't click on anything in that window (but it worked fine with Internet Explorer). However, it's working again today! Maybe my Windows 2000 is about to crash (which is pretty normal, I guess!)." I don't have any problems with Linux, at least.
When I save the Netscape download manager as an xls file, it is not recognized as such!
ttns4
Post10-12-2002, 13:52    Subject: Ulf's Draft Calculation Tool - Loading Test Quote
Hello Rainer,
I seem to have a problem at work.
The main page keeps crashing when I try to load it.
After that, I have to manually close Internet Explorer, which closes all open Explorer windows.
I'm trying it again from home.
Is the link to the ventilation calculator only available on the main page?
I can't reach it.
(It's not likely to be a problem with processing power; we have quite generous equipment from the company.)
Bye Thorsten.
TDIBubi
Post10-12-2002, 14:06    Subject: Give me your email address and I'll send it to you as an attachment! Quote
Please give me your email address and I will send it to you as an attachment!
Arne
Post10-12-2002, 14:36    Subject: Ulf's Draft Calculation Tool - Loading Test Quote
Right-click on the link and select 'Save target as...'
arne
ttns4
Post10-12-2002, 19:32    Subject: Ulf's Draft Calculation Tool - Loading Test Quote
Hello everyone, again.
'From home, I was able to download the software without any problems.'
Thank you for your support.
No new posts Draft Test / Performance Test 2000-4000 rpm Technical Articles
No new posts @ Ulf - Draft Angle Calculator Diesel Engine Technology
No new posts Tire rolling resistance in the draft calculator Diesel Engine Technology
No new posts Ventilation Calculator: Calculate Airflow Online Diesel Engine Technology
No new posts Are rotating masses in the flow solver too large? Diesel Engine Technology
