Threaded suspension Ibiza GT TDI - Problem ??????
MONCHI
Post21-10-2002, 10:08    Subject: Threaded suspension Ibiza GT TDI - Problem ?????? Quote
Hi and Hello,
'I installed a coilover suspension in my 1998 Ibiza GT TDI 110PS this Saturday. When I lower the front of the car as much as it looks good, the tires rub against the inner lining of the wheel arch when taking sharp turns. There's a small protrusion on each side inside the wheel arch. I removed the lining and will tape it with duct tape. Does anyone have experience with coilover suspensions on an Ibiza?'
Monchi.
Translated on 19-07-2026, 11:25.
Widale
Post11-12-2002, 10:00    Subject: Coilover suspension for the SEAT Ibiza Quote
I installed a KW coilover suspension system (FW) in my VW Polo Variant.
'With the dimensions 7 1/2 x 16 and 195/45-16, I generously cut out the wheel arch liner, created edges, widened the fender flares (especially in the front area), and modified the side mounting bracket for the bumper.'
Since then, nothing rubs anymore; ground clearance under protection is approximately 55mm.
Best regards, Alex.
Translated on 19-07-2026, 11:27.
No new posts Electrical problem in wet conditions, Seat Ibiza 6L ASZ Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Polo 9N / Ibiza 6L / Fabia 2: Generator does not charge Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Seat Ibiza 6L error code 16415 - Bank 1, Sensor 1; Heater... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Speed Signal Problem Ibiza 6K AFN - K-Power On-Board Diagnostics (OBD)
No new posts Adjust Coilover Suspension: How-To Guide Transmission, Chassis, Body & Interior
No new posts Bilstein B16 PSS9 Coilover: Dealers & Sales Transmission, Chassis, Body & Interior
No new posts Coilover Suspension Adjustment Guide Transmission, Chassis, Body & Interior
