TDI_Chris
14-09-2006, 17:11 Subject: 1.9L TDI, AFN, Problems with Turbocharger Pressure Control (2) |
Here's the new test drive.
Car overheated.
AGR bypass valve, also known as N75.
AGR to (AGR hose open, vacuum side of valve disconnected to prevent vacuum loss).
MWB 3.8.11
Marker 1: Full throttle every 2-3 seconds at approximately 2500 RPM (3rd gear).
Marker 2: Full throttle every 2-3 seconds at approximately 3000 RPM (3rd gear).
Marker 3: Full throttle every 2-3 seconds at approximately 3500 RPM (3rd gear).
Marker 4: Full throttle every 2-3 seconds at approximately 3500 RPM (2nd gear).
Marker 5: Acceleration from 1500 to 3600 (3rd gear). Sure, here is the translation of the text from German to English:
"Gang"
"Gang" can be translated as:
* Gangway
* Passage
* Corridor
* Hallway
* Walkway
* Path
* Trail
* Track
* Route
* Way
* Road
* Street
* Avenue
* Boulevard
* Lane
* Alley
* Passage
* Corridor
* Hallway
* Walkway
* Path
* Trail
* Track
* Route
* Way
* Road
* Street
* Avenue
* Boulevard
* Lane
* Alley
* Passage
* Corridor
* Hallway
* Walkway
* Path
* Trail
* Track
* Route
* Way
* Road
* Street
* Avenue
* Boulevard
* Lane
* Alley
* Passage
* Corridor
* Hallway
* Walkway
* Path
* Trail
* Track
* Route
Please provide the German text you would like me to translate.
Christoph.
| Description: |
 Download |
| File name: |
test3.xls |
| File size: |
115.5 KB |
| Downloaded: |
778 times |
