Passat 1Z with excessive boost pressure
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Upload
semteX
Post25-09-2006, 13:29    Subject: Passat 1Z with excessive boost pressure Quote
The graphical representation is colored yellow.
The yellow area indicates a section where you can accelerate while going uphill.
maprun.xls
 File name:  maprun.xls
 File size:  81.5 KB
 Downloaded:  587 times
Translated on 15-07-2026, 1:05.
No new posts Power Loss: Air Mass/Boost/Timing OK? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Install Parking Heater in VW Passat 3BG Troubleshooting & Guides
No new posts Passat B5: Intercooler Hose Special Offer - 74/96 kW Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A4 TDI: Limp Mode Due to High Boost Pressure On-Board Diagnostics (OBD)
No new posts Solved: 1Z Power Loss Due to Overboost Pressure On-Board Diagnostics (OBD)
This topic is locked, you cannot edit or reply. Vibrationen bei hohem Tempo Transmission, Chassis, Body & Interior
No new posts Sharan TDI: Service for Excessive Carbon Buildup? On-Board Diagnostics (OBD)
