Opel Astra G: Troubleshooting Performance Issues
AstraG
Post16-09-2006, 16:36    Subject: Opel Astra G: Troubleshooting Performance Issues Quote
For quite some time, I've been experiencing a problem with my Astra where I have power drops at certain engine speeds.
For example, when I'm driving at 130 km/h, I have the feeling that the acceleration is happening in a wave-like manner. Furthermore, the turbocharger only really starts to work properly at 2800 revolutions. At speeds below 2800 revolutions, the acceleration is like a ship icon_wink.gif.
My fuel consumption has noticeably increased. I just barely passed the emissions test in February.
Based on my previous research, I suspect the mass airflow sensor, as the first one failed when the car had approximately 65,000 km. Now, it has 160,000 km.
I've also heard that it's quite common for the mass airflow sensor (MAF sensor) to fail every 80,000 to 100,000 kilometers.
Has anyone here had experience with the measurement signal voltages that the mass airflow sensor (MAF) should provide?
I received the wiring diagram from Bosch.
Pin 1: Temperature sensor.
Pin 2: Power supply voltage.
Pin 3: Ground.
Pin 4: 5V reference voltage.
Pin 5: Measurement signal [+]
Does anyone have a wiring diagram or a circuit diagram showing all the connections of the control unit?
Translated on 09-10-2026, 6:43.
Kosta
Post20-09-2006, 15:54    Subject: Opel Astra G: Troubleshooting Performance Issues Quote
HI.
Renewing the LMM (likely referring to a mass airflow sensor) would be one option, but first, let's check the error codes.
Read out the data and, if necessary, measure the parameters!
Translated on 09-10-2026, 6:45.
AstraG
Post20-09-2006, 16:42    Subject: Extract Data: How to & Best Practices Quote
Recently, I had the error memory checked. There were no errors registered in the error memory. Everything was fine.
The value for the mass flow rate (LMM) was also displayed, but only when the system was stationary. I don't know what it looks like when the system is in motion.
I definitely received the complete datasheet for the mass airflow sensor from Bosch.
I will compare the voltage values provided by the mass flow meter with the specified values according to the datasheet. Let's see what the investigation reveals.
Translated on 09-10-2026, 6:46.
Post20-09-2006, 17:22    Subject: Opel Astra G: Troubleshooting Performance Issues Quote
Investigating the LMM values while the engine is running costs a fortune... You wouldn't notice the reduced power when parking in the garage, would you? icon_wink.gif
Translated on 09-10-2026, 6:47.
AstraG
Post27-09-2006, 22:23    Subject: Opel Astra G: Troubleshooting Performance Issues Quote
Okay, after replacing the mass airflow sensor, I've achieved the familiar performance again.
Approximately 30% more performance than before.
No new posts Various errors in my 8K (Audi A4, year of manufacture 2008) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Not LLM: Poor Performance Explained. Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AFN Engine Performance Data, MJ 1998 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Opel Astra 2008: Specs, Review & Price On-Board Diagnostics (OBD)
No new posts Opel Astra 1.7tds Diesel Pump, 1996 Diesel Engine Technology
This topic is locked, you cannot edit or reply. Opel Astra G won't start - Troubleshooting. Diesel Engine Technology
No new posts Rail pump, Opel Astra, likely faulty Diesel Engine Technology
