LMM Pinout: Switched Positive & Location
Juergen B
Post13-12-2002, 9:12    Subject: LMM Pinout: Switched Positive & Location Quote
ich suche dringend die Pinbelegung für den Stecker am Luftmassenmesser, also genauer gesagt das Kabel wo der Messwert des LMM rausgeht. Laut eines Postings hier müsste das am Stecker der Pin 5 sein (Kabelfarbe?). IIs that correct?
Besides that, I'm currently trying to figure out the best place to tap into a switched positive connection for power supply.
I would like to install a power box from Zemotex (D-Chip).
'Does anyone have a tip?' or 'Any suggestions?'
Thank you, Jürgen.
Addition: Volkswagen Golf IV TDI, 66 kW, ALH engine.
Translated on 27-07-2026, 0:24.
Rudi
Post13-12-2002, 9:43    Subject: LMM Pinout: Switched Positive & Location Quote
Hello Jürgen,
What kind of car is it?
Best regards, Rudi.
Juergen B
Post13-12-2002, 9:50    Subject: Golf IV TDI ALH: 66kW Engine for Sale Quote
I forgot, sorry.
Volkswagen Golf IV TDI, 66 kW, ALH engine, manufactured in 1998.
Translated on 27-07-2026, 0:25.
Rudi
Post13-12-2002, 12:40    Subject: LMM Pinout: Switched Positive & Location Quote
During the 1997/98 period, the change was made from a 6-pin to a 5-pin MAF sensor connector. If it's the 6-pin connector, you should use pin 6 (purple/brown); with the 5-pin connector, use pin 5 (brown/blue).
Before connecting anything, please measure the voltage at the corresponding pin. It should be around 1.5V when idle and increase as the speed increases.
As a switched supply, for example, the positive connection for the shut-off valve can be accessed at pin 8 on the ESP connector.
Best regards, Rudi.
Translated on 27-07-2026, 0:26.
Juergen B
Post13-12-2002, 13:11    Subject: Best German Restaurants: Find Top Rated Dining Quote
Thank you.
You saved my weekend icon_smile.gif.
Best regards, Jürgen.
Translated on 27-07-2026, 0:27.
No new posts KST 1J0 959 799 Pinout: Connector Diagram & Info On-Board Diagnostics (OBD)
No new posts MSG Connector Pinout 184Nm 1Z On-Board Diagnostics (OBD)
No new posts Pinout diagram for 1.7 SDI engine control unit On-Board Diagnostics (OBD)
No new posts ECU Pinout: Find Connector Pin Assignments On-Board Diagnostics (OBD)
