Error Codes: What Do You Think?
New Topic Reply 🔗 ⭐ 🖹 Dieselschrauber - Index » On-Board Diagnostics (OBD)
Tobi12345
Post07-10-2006, 18:22    Subject: Error Codes: What Do You Think? Quote
VAG-COM Version: DRV 607.3-UD
Saturday, October 7, 2006, 4:22:10 PM.
Vehicle type: 3B - B5 Passat 1997>2004
Scan: 01 02 03 08 16 17 19 35 36 37 46 55 56 57 58 76
Chassis number: WVWZZZ3BZ3E238333
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Ein leichter Wind weht durch die BĂ€ume, und die BlĂ€tter rascheln leise. Es ist ein wunderschöner Tag, um draußen zu sein."
Address 01: Engine.
Part Number: 038 997 019 A
Part: 1.9L R4 EDC G000AG 6204
Encoding: 00001
Workshop No.: WSC 20940
WVWZZZ3BZ3E238333 VWZ7Z0B6573013
"One error found:"
18263 - Data bus drive: Software status monitoring.
P1855 - 35-10 - - - Interrupted.
Readiness: 0 0 X X X
Address 02: Transmission.
Part Number: 3B0 927 156 S
Component: AG5 01V 1.9l-PD RdW 2224
Encoding: 00103
Workshop No.: WSC 05311
"One error found:"
18265 - Last signal: Error message from the engine control unit.
P1857 - 35-10 - - - Interrupted.
I've never seen this error code in a message before. What could be the possible causes?
Best, Tobi.
A6 Avant 3,0TDI Tiptronic Bj. 02/2008
Translated on 29-09-2026, 16:17.
Ross-Tech-Support
Post07-10-2006, 18:55    Subject: Error Codes: What Do You Think? Quote
The code 18263 likely originates from the fact that a new control unit has already been installed in your vehicle, probably after you reported an issue related to power output during the winter months. Essentially, it's just a notification that can be ignored.
I would keep 18265 under closer observation, but I would delete it for now.
Translated on 29-09-2026, 16:20.
Tobi12345
Post07-10-2006, 18:58    Subject: Error Codes: What Do You Think? Quote
The error 18263 has only started appearing in the last few days, but there are no other noticeable side effects.
The Derim gearbox has been installed for a while now.
Translated on 29-09-2026, 16:21.
No new posts Error codes 19804/P3348 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts MKB AMF Error Codes: Causes and Effects Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Error Codes, Causes and Effects for MKB ASZ, AXR, ATD Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts What do you think of this vehicle concept? Diesel Engine Technology
No new posts Spot the Mistake: Find the Error in This Image Diesel Engine Technology
No new posts N75 Solenoid Location: Find it in this Picture! Diesel Engine Technology
No new posts Airflow/RPM Log: Analysis & Optimization Diesel Engine Technology
